Old 03-24-2013, 11:39 PM
deezy deezy is offline
Vehicle: 2003 Dodge Ram 1500
deezy is on a distinguished road
Default 03 Turn signal problem
Hi There,
I have an 03 5.7L 1500 that I'm having trouble with the trailer lights. The truck is fairly new to me but looks like a factory installed wiring system. The problem is with the left turn signal, it will not indicate breaking or turning? The wiring to the truck does though. I have a 7 pin and a 4 pin and both do not work. (all other pins work) I have checked the fuse and it is fine, the one thing that I noticed was that when removing the fuse the clicking sound ( relay?) stops and when replaced it is noticeably quieter than the right signal clicking? (If that makes sense?)
Any info would be greatly appreciated.
Thanks!
Old 03-25-2013, 08:18 AM
Rep:1909
While the fuse may be good, that doesn't mean there's power going across it. Check, and if there isn't any, you probably have a FCM going bad, but you'll need to do a bit more checking before condemning it.
Old 03-25-2013, 10:22 PM
Hi Thanks for the reply, I did check it with a meter and it was showing constant power across the terminals in the block
Old 03-26-2013, 08:08 AM
Rep:1909
Ok, next thing is to run down the wiring and see where the voltage is dropping. I would start with the wiring on the IPM connector and work my way back.
