Old 03-25-2013, 01:16 AM
80strucksrule7 80strucksrule7 is offline
Vehicle: 2007 ram 1500
Trim Level: Base
80strucksrule7 is on a distinguished road
Default Need backspacing help asap!!
Ok 2007 ram 1500 2wd 17 stock rims, 285/70 17s on right now can I run a 17inch 6.5 back spaced rim?? it looks like the stock configuration is 5.5 back space. If not if I lift it can I run them?
Old 03-25-2013, 01:24 AM
Trim Level: Base
need help because getting rims tommarow morning...
Old 03-25-2013, 01:34 AM
RealTreeRam12 RealTreeRam12 is offline
Vehicle: 2012 Dodge Ram
Color: SageBrush Pearlcoat
RealTreeRam12 is on a distinguished road
You also need to look at offsets as well.
Old 03-25-2013, 01:37 AM
Read thru this section
http://www.ramforumz.com/forumdisplay.php?f=129
Old 03-25-2013, 01:45 AM
Trim Level: Base
well I measured my stock rim and it looks like 5.5 inches it looks like I have .75 of a inch before my tire will hit the upper arm. So can I lift the front end a couple inches so the tire will fit without hitting the upper? Really dont want to use a wheel spacer but these rims are sickkk.
Old 03-25-2013, 09:20 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
For every quarter inch increase in backspace, your wheel moves in 6mm. Therefore, moving from 5.5" backspace to 6.5" backspace reduces the space between the inside of your tire and the control arms by an inch..Thats a lot to reduce the inside by..
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 03-25-2013, 09:25 AM
LowUFO's Avatar
Rep:1109
You can do a level and gain some clearance, because the tire will turn to the inside and not contact with the control arms at the same height anymore. But You're moving the wheel and tire in and that alone will look weird on the truck. Let alone how adverse it will affect the handling to narrow your track by two inches total..
Old 03-25-2013, 12:45 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
I wouldn't go that way. I'd go less back spacing.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 03-25-2013, 03:46 PM
LowUFO's Avatar
Rep:1109
Exactly.
(blah blah blah for minimum characters to post)
Old 03-25-2013, 03:50 PM
Outlaw's Avatar
Color: Bright white
Rep:435
X2!
That's annoying
[/CENTER]
