Trailer Wiring Issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 03-25-2013, 01:57 PM
randycj7 randycj7 is offline
Vehicle: 2009 Ram 1500 4X4 Crew Cab
Rep:12
randycj7 is on a distinguished road
Question Trailer Wiring Issues
I used my 09 Ram to tow my car trailer today and noticed a small problem, I have only owned this truck for a month or so and I don't belive it had ever towed a trailer before this, I bought and installled a brake controler and that works fine. The problem is there seams to be no constant 12V at the plug at the back. Does anuone know if there is something I need to do, I know on my old Chevy I had to install a fuse in order to get 12v to the back, is it something like that? Thanks in advanced for your help.
Old 03-25-2013, 03:58 PM
sandawilliams's Avatar
sandawilliams sandawilliams is offline
Vehicle: 2014 2500
Rep:23
sandawilliams is on a distinguished road
Originally Posted by randycj7 View Post
i used my 09 ram to tow my car trailer today and noticed a small problem, i have only owned this truck for a month or so and i don't belive it had ever towed a trailer before this, i bought and installled a brake controler and that works fine. The problem is there seams to be no constant 12v at the plug at the back. Does anuone know if there is something i need to do, i know on my old chevy i had to install a fuse in order to get 12v to the back, is it something like that? Thanks in advanced for your help.
if you have the factory tow package everything will be pre-wired to the back plugs. If so take a 12 volt test light and check the back plugs to make sure each circuit is working.
Old 03-26-2013, 10:58 PM
Rep:12
I did test the plug at the back and everything else is working but the 12v positive, that is why I was wondering if there was a fuse that I needed to install like on my old chevy.
Old 03-27-2013, 11:50 AM
Vehicle: 2014 2500
Rep:23
you may have blown the fuse that runs the 12V. There isnt a fuse that needs to be installed to activate the circuit so my best guess is a blown fuse. Owners manual should help on which fuse.
