Old 03-25-2013, 06:54 PM
finsup finsup is offline
Vehicle: 2013 Ram outdoorsman
Color: prairie pearlcote
finsup is on a distinguished road
Default Level Front....
Do most of you Ram owners level front end to get away from that "rake" look. Owned a HUMMER before this and with GM all you had to do was turn the torsion bar a few cranks. Is there a kit that has to be purchased to level, how much, and is it avail. at Dealer. Thanks
Old 03-25-2013, 07:10 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2051
The 1500 Rams have a strut suspension on the front, no torsion bars. There are many companies out there that make spacers that simply bolt on top of the strut. I got mine from Hellbent Steel for $80. That's about the cheapest way you can go. However since you have an outdoorsman you don't want to go with a 2.5" leveling spacer. The outdoorsman struts are already set higher than the standard. You'd want to stick to a 2" spacer if that's the route you want to take. Now that being said, I recommend going with the Bilstein 5100's. They are an adjustable strut that allows you to set the height you want. It's essentially the best way to level the new 1500's but you also pay a little bit more for it. Contact Jeremiah (jhinkle1989) at Discount Auto Performance. He'll get you the best pricing for the Bilsteins.
Old 03-26-2013, 07:00 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
what he said ^^^^^^^^^^^^^^^^^^^^^^
Old 03-29-2013, 11:41 AM
Ziegler00's Avatar
Ziegler00 Ziegler00 is offline
Vehicle: 2012 Ram Express Quad Cab 2wd
Color: Deep Red
Rep:13
Ziegler00 is on a distinguished road
i wish we could use the 5100's for 2wds
2012 Ram 1500 Express Quad Cab 2wd
"The high cost of livin, aint nothin like the cost of livin high"
