Old 03-25-2013, 08:30 PM
Fuelup Fuelup is offline
Vehicle: 2012 dodge ram 1500 sport
Fuelup is on a distinguished road
Default Biggest lift?
Hey guys I'm looking for a big lift for my ram. I have a 6" bds with a 3 " body lift. But it's not high enough for me. Was wondering if anyone knows where I can find a bigger lift so I can run bigger tires
Old 03-25-2013, 08:47 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Smile
Hey fuelup pal. I too want an 8 inch suspension lift for my ram but It doesn't exist. I have a stigma against body lifts no offense pal. I just don't want one on my truck. It'll have to be suspension only or nothing at all. That said google headhunter ram. It's a sick looking ram black n green w/ skulls all over but it's lifted sky high & has some serious sneakers on it. Its 16 inches of lift by 3rd coast suspension. Give those folks a call & see what they say. I'd say your looking at $5 grand + for something like that lift alone.... I'd be way happy w/ an 8in but it just doesn't exist. So I'm thinking 6 in fabtech & done. Good luck pal.
Old 03-25-2013, 09:19 PM
mswift's Avatar
mswift mswift is offline
Vehicle: 2007 Dodge Ram SLT Big Horn
Rep:31
mswift is on a distinguished road
Wow just googled head hunter ram that thing is AWESOME
This truck is sponsered by
https://bullysperformance.com/
Check out there website for great mods at a great price
-Mike-
My work number is 911
Old 03-26-2013, 12:05 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
You can get an 8" lift it requires adding adjustable shocks to the front, and a rear coil spacer in the back, most will use bilstein 5100's to achieve an additional 2.75".
Thanks
Jeremiah
Discount Auto Performance
Old 03-26-2013, 08:08 PM
Hemi N Haw's Avatar
Rep:139
Smile
Thanks
Jeremiah
Thanks for the info pal. Now that you mention it I've seen it on here on a few spec sheets. I just wish they'd make a kit w/ it all there. I have to think that given the addition of spacers & shocks that stress the suspension to raise it further would make the ride even more stiff than just the lift kit would it's self. I guess thats the only option.
Old 03-26-2013, 09:16 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
It's not as near bad as you would think, there alot of member here that run 8" lifts, and If you are interested in a kit that would "come" with everything in the box we could surely put one together for you I have done it a couple of times for a few different customers, and we could work you a really good deal as well.
Thanks
Jeremiah
Old 03-26-2013, 10:02 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Op what size tires are you running? Trying to run? I'm almost maxed out on lift at about 11" right now and have Iron Bulls front and rear. You're not gonna fit anything over a 38 unless you stay with a 13.50 tire. Does your bds have the preload spacer installed? I've seen a lot of shops not install it. If its nnot your running 7.5" of lift haha.
[CENTER][SIGPIC][/SIGPIC]
Old 03-27-2013, 04:27 PM
Originally Posted by candy08 View Post
I'm almost maxed out on lift at about 11" right now .
Unless you go custom, this is the highest you can go.
Actually 11.25" of 'actual lift' is the highest you can go and that's with a 6" RCX, maxed Bilsteins and 3" body lift
On paper this 11.75"
Old 03-27-2013, 06:28 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
like mentioned above adding bills at 2.75 will get you the 11.75" lift....im at 10" now and i wouldnt want anymore, im actually probably gonna go back down to the 2.1 setting on my bills. and end up at 9.25, but with new tires ill still be the same height-ish.
2011 Hemi RCSB Sport 4x4
Old 03-27-2013, 06:40 PM
Coming from me....that's what I did....man changed my settings 3 times to find my perfect set up
