96 dodge ram stalling - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-26-2013, 12:34 AM
Canales22 Canales22 is offline
Vehicle: 1996 dodge ram 1500
Trim Level: Xlt
Canales22 is on a distinguished road
Default 96 dodge ram stalling
I have a 96 dodge ram 1500 with the 5.2l engine and its been stalling everytime it's starts in the morning and backfires as I drive as well as rpms drop and the gen and check engine light will turn on while the rpms go down also dies when I come to a stop must press the gas pedal a little to get it started and once I drive like 2 miles or so it seems to run fine after that as long as its warm. I have replaced the cap and rotor as well as the iac valve that people suggested on the the top of the motor that connects to the throttle body. Any advice or help will be greatly appreciated.
Old 03-26-2013, 08:59 AM
Resident Technician
Rep:1915
What DTC's are stored in the PCM?
Old 03-26-2013, 02:14 PM
Trim Level: Xlt
Default PCM codes
The Only codes I get from the check engine light are 12 and 55
Old 03-26-2013, 02:38 PM
Resident Technician
Rep:1915
You need an OBD II scan tool to get the codes.
Old 03-26-2013, 04:09 PM
Trim Level: Xlt
Default Confused ????
From what I've read there is no way to hook up obd2 to my year truck and the only way to read codes is to turn the key back and fourth to on to read the check engine light?
Old 03-26-2013, 04:17 PM
Resident Technician
Rep:1915
Not sure what you've been reading, but OBD II became standard in '96. The DLC is under the drivers dash.
Old 03-26-2013, 10:05 PM
Trim Level: Xlt
It said pass. No codes found.
96 1500, dodge 318 tps, help me, stalling
