2004 Ram 1500 Front Camber Kit? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 03-26-2013, 12:46 PM
Dhawk13's Avatar
Dhawk13 Dhawk13 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver with Blue Pearl Flamed Clear Coat
Dhawk13 is on a distinguished road
Default 2004 Ram 1500 Front Camber Kit?
Hello i have a 2004 Ram 1500 and i have a 5/6 drop on it and my front two tires are cambering in the negative. I went to get it aligned and the guy said that he cant fix the camber anymore because it is maxed out and it cant be adjusted anymore. I have done some researching and found out that you can buy a camber kit for the front and it will fix it. Has anyone ever had any experience with these or advice? Thanks
Just drag it!
Old 03-30-2013, 08:06 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Is it possible that you could cut the slots longer where the control arm bushings bolt thru? How much negative camber? I run - 1.5 degrees all around on my Magnum wagon with no abnormal wear. Car corners on rails, btw.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-10-2013, 11:08 PM
Dhawk13's Avatar
Not sure on the degree of negative camber, just dont really like the look that it gives me.
Just drag it!
