Old 03-26-2013, 10:21 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Originally Posted by topsub View Post
I just heard its a good brand. I am open to suggestions. My main focus is ride quality and quality parts. What are some suggestions. I did hear fox shocks are the shit tho. I know raptor uses them on there trucks.
I am open to suggestions, I have the money to do this and want to make sure i understand what i need so i don't get fooled by any local shop and pick the right brand. The local shop i called said they have been installing a lot of ready lifts. (http://www.readylift.com/)
Haha
It is good sstuff, but you could get the same ride you want or better for a grand less. For instance my setup is taller, rides better, has more travel, more ground clearance and still carries the same quality and warranty as BDS. Oh and it will be level...
I say do some research on here on the other forums and you will see the light!
[CENTER][SIGPIC][/SIGPIC]
Old 03-26-2013, 11:09 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
Originally Posted by candy08 View Post
Haha
That would Be great information to have! Care to share your setup?
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted
My Build Progress
Old 03-27-2013, 07:25 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
Rcx ftw!!!!!!!!!!!!!!!!!!!!!!!!
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 03-27-2013, 08:17 AM
candy08's Avatar
Rep:213
Old 03-27-2013, 11:00 AM
Color: Blue
Rep:156
Now with roughcountry am i able to use my stock 20inch rims with the lift kit? I know some lift kits don't?
Also is it 100% bolt on kit?
Also if i got the RCX kit would getting Bilstiens 5100 be an upgrade to the ride vs using the stock ones that come with it?
My Build Progress
Old 03-27-2013, 11:38 AM
candy08's Avatar
Rep:213
With 1/4" wheel spacers you can use oem wheels.
No 6" kit is 100% bolt on, I don't think anyway.
The Bilstein 5100s will be an upgrade to any kit due to your upgrading the oem struts.
Old 03-27-2013, 12:46 PM
Color: Blue
Rep:156
How would people rate a Fox Shock vs bilstein 5100s?
My Build Progress
Old 03-27-2013, 12:54 PM
candy08's Avatar
Rep:213
That's a coilover not just a strut swap.
You're splittin **** hairs. Both are good just pick one. Depends on the series you want and how deep your pockets are.
You wont notice a difference in ride between the two. Now you will notice firmer street ride frkm both over your oem struts on the road, in a bad way. Neither shine till you get off the pavement.or the pavement is uneven or potholed up. With that said all your gaining is looks and a skinnier wallet if its a Pavement Pounder.
Old 03-27-2013, 01:06 PM
Color: Blue
Rep:156
So it seems a 6" RCX kit with bilstein 5100 all around would be a solid choice? Is there anything else thats worth upgrading while i am doing this?
My Build Progress
Old 03-27-2013, 01:24 PM
candy08's Avatar
Rep:213
That is a good choice!
This is what I would do..
Choice one would be what you just said.
Choice two that above but with the Bilstein 5165 14" Remote Resi shocks like I have
Choice three would be the Fox IFP up front with the FOX/BDS shocks out back
Choice four would be the Fox IFP up front with some FOX remote resis out back.
All are good choices. I wanted to do those FOX IFPs like you posted earlier but already had the adjustable bilstiens up front and IM ocd so I couldnt mix and match shocks. I went though all of this not to long ago as well lol.
