My "Project" Truck...... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-26-2013, 08:19 PM
CBW1999 CBW1999 is offline
Vehicle: 1999 Ram 1500 Sport
CBW1999 is on a distinguished road
Default My "Project" Truck......
I bought my “project” at auction about a month ago. I knew it was going to need quite a bit of work but, nothing I wouldn't be able to deal with (for the most part). Bear with me, I have some physical limitations so this project may take some time.
As I crawled in, over, under and through- finding all the problems I made quite a list of things to do. It is obvious that not much attention was ever given to maintenance. It is a 1999 with only 72,000 miles, second owner had it about a year before trading it. Not sure if they beat it or it just was from a lifetime of neglect. As I searched the internet I found this forum as an excellent resource to help identify some of the oddities I was finding.
The weather hasn't been the greatest so I have spent my time sourcing parts and ordering them to be ready for the attack. Finally this week I had the chance to start.
Top of the list is the ever so popular intake plenum repair. About 4 hours over 2 days and I was able to get everything unbolted, out of the way and removed. I didn't bother to take before pictures- I'm sure most members have seen it before. I will however post the “after” pics.
It would appear that someone tried to repair it previously and did a horrendous job. Best I can guess, they reused all the bolts and didn't use a torque wrench. None of the manifold bolts took much to break loose. Although I soaked them for days previously with PB Blaster, I would still expect them to need more than a casual turn of the ratchet to loosen. Thankfully, only one broke- I am suspicious that it already had....... The pan bolts were easy too- one of which was already loose.
I'll spend the next day or two cleaning parts and doing the “Keggar Mod” and removing the “ears” on the throttle body.
Since it is all apart, I'll be doing the typical tune up stuff and replacing the valve cover gaskets. IMHO- might as well do it all while its opened up.
Again- before I put it all back together, I'll post pics of the results.
Old 03-26-2013, 09:13 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Welcome to the forumz. We always like to follow a good, thorough project around here. Looking forward to it.
Old 03-26-2013, 09:17 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
welcome bud...i'll be here to watch the progress
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 03-27-2013, 11:10 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Hey welcome to the forum and best of luck with this project. I will for sure be watching this, to see this truck resurrected from the grave.
IG:@briley59
