Old 03-26-2013, 09:34 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
Default level rear with front
2012 rcsb 4x4 all i want to do is lower the rear to match the front so my truck dont look jacked up like joe dirts hemi (the peice) whats my best options for going bout this thanx
Old 04-02-2013, 11:00 PM
donnybrian donnybrian is offline
Vehicle: 2006 dodge 2500
donnybrian is on a distinguished road
most trucks have a few spacers factory installed about the rear axle, below the leaf springs. take those out ( you may need to get shorter bolts and u bolts but that would be the best way to lose the height with out the weight capacity. ( the spacers are about 4-5 inches long and the width of the leafs)
Old 04-03-2013, 01:38 PM
sporty11's Avatar
sporty11 sporty11 is offline
Vehicle: 11 Sport
Trim Level: sport
Rep:23
sporty11 is on a distinguished road
there are no leafs on the rear of the 4th gen 1500's. I installed 2" lowering springs from tuff truck and it dead levelled the rear with the front. They work very well, ride is the same if not better and you gain 10% load capacity due to the progressive rate coils.
I believe that Ground Force makes them as well.
Bilstein 5100's, 1.25" RCX BL, Toyo ATll 35x12.5, 20" Fuel Throttle 0 Offset, 10" L3's, 2500w Mono amp, AFE Stage 2 Intake, 180 deg, 14" Magnaflow, Stage 2 Jet Performance Module
Old 04-03-2013, 01:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
A few companies make rear leveling kits. They consist of new coil springs for the rear, some have shocks too. otto-max is one of the companies. ground force is another. I think there are a few others, too.
I cut some RT rear springs and put them on my quad cab and it dropped the rear 1". Stock shocks, I am happy. Others have cut their stock springs as well with varied results.
Sean
