Low trans pressure? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 03-26-2013, 09:58 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Default Low trans pressure?
So I was out doing a few wot runs from a dead stop, testing out the custom tune and as soon as I floored it, my check engine light came on.
I scanned th code with the tuner and it said it was low transmission pressure. I checked the trany fluid level and it was at the first hole under hot. Could that be why it said low trans pressure? Does it need to be at the second hole when it's at operating temp?
I cleared the code and it hasn't come on since
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 03-26-2013, 11:03 PM
Rep:156
Ok so according to the owners manual, that's where it should be. So what would cause that to trip? Going wot sloshing the fluid enough to trip it maybe?
Old 03-27-2013, 09:20 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:501
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Did you find a P0868 Line Pressure Low fault? And no other faults?
That's strange because P0868 (by itself) should not light the CEL, as far as I know.
Yes, your fluid level should be in between the "HOT" holes when the trans is at operating temp (180F is our standard temp for measuring it).
Old 03-27-2013, 02:53 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Are you running a line booster?
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 03-27-2013, 11:59 PM
Rep:156
Negative, no line booster. And so far hasn't come back after I cleared it
Old 03-28-2013, 07:51 AM
Rep:165
That's good to hear, I put one on my 2010, it also threw a code, very disconcerting when you see the check engine light start to flash, it was while I was towing our TT, anyway I was able to get it to a Canadian Tire and they scoped it said it was "low line pressure", can't remember the code number, they cleared it and I pulled the sonnax booster off and fired it in the bush, no issues at all after I got rid of it.
