Old 03-27-2013, 04:57 AM
BIGTEXDODGE's Avatar
BIGTEXDODGE BIGTEXDODGE is offline
Vehicle: 2008 RAM leramie 4x4
Trim Level: leramie
Color: cool venilla
BIGTEXDODGE is on a distinguished road
Default 150 shot of nitrous
hey guys new to this forum....
I have just ordered myself a nitrous kit and was wondering what peoples thoughts are on this subject. and if people might have already done this to there ram
Old 03-27-2013, 06:42 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
A whole sub-forum dedicated to nitrous
http://www.ramforumz.com/forumdispla...ysprune=&f=136
Old 03-27-2013, 09:47 PM
I push the skinny pedal
Rep:3277
I hope you ordered a wet kit. Running a 150 shot needs to have a lot of effort put into the engine build before you can just hit the button and go. 100 is considered the top end of a "safe shot" with 125 being the limit on a stock rotating assembly. Either way, you really need to work up to the larger shots so you can map your AFR accurately to ensure you don't go stoichiometric at WOT and pop the top of your piston.
To do big shots with relative safety you need to get 2-3 stage colder plugs, pull 4-8 degrees of timing from STOCK, run high octane fuel (highest available), and monitor your A/F ratio very carefully.
You really need to have a look through the nitrous forum on here to get a gauge of what you need to do to run nitrous safely. We don't condone the "spray it 'til you break it" mentality of the former decade.
Kurtis
Old 03-28-2013, 12:03 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
yes we have...
http://s1127.photobucket.com/user/ch...ml?sort=3&o=20
http://s1127.photobucket.com/user/ch...ml?sort=3&o=16
Old 03-28-2013, 04:02 AM
Trim Level: leramie
Color: cool venilla
just watched the vids and sounds bad ass. what all have you done to the motor? and any issues with the system?
Old 03-28-2013, 04:04 AM
Trim Level: leramie
Color: cool venilla
the kit is from 70 to 150, i def will work my way up. and yes it is wet. i am running the highest octane because i have my baby tuned on the highest octane tune. she def will get all new internals
Old 03-28-2013, 10:15 AM
chefred112's Avatar
Rep:656
...stock bottom end with over 234k miles
step colder ngk 4306 spark plugs, 180 tstat, cai, cam, heads, headers, cutouts, cat deletes, exhaust, and a big smile whenever i drive her
Old 03-28-2013, 10:17 AM
chefred112's Avatar
Rep:656
..and a Zex wet setup...
Old 03-28-2013, 09:59 PM
Trim Level: leramie
Color: cool venilla
That's ****in sick. Is she your daily driver?
Old 03-29-2013, 02:47 AM
chefred112's Avatar
Rep:656
234,500+ miles and counting
