Old 03-27-2013, 04:14 PM
black71gp black71gp is offline
Vehicle: 2001 dodge ram 2500
black71gp is on a distinguished road
Default Brake ABS- Not sensor related.
Hello,
I have a 01 ram 2500 with awal.
problem is with my brake and ABS lights,
I have had the module rebuilt because it was bad when i bought the truck. and have changed out all three sensors.
I ran a scanner
code 22 and 26 come up, which is no input from front left or right sensors
I did a data stream with the scanner and the left front reads sparatic speeds over 40 MPH, and the right front never reads speeds.
My lights do not come on until i travel over 50MPH, if i stay under that, i do not get a light, but I also do not have working ABS.
I dont know if the sensors I got for the front are bad, or what else could be going on. any insite into what I may need to do in order to fix this problem and have working ABS on my truck again?
Old 03-28-2013, 10:27 AM
Rep:1909
Could be one of several potential problems. Check out the attached diagnostics. Some steps require a live data stream from a scan tool, but if you don't have access to one, you can still perform the other steps in an attempt to resolve the problem.
File Type: pdf 7_1_4 INTERMITTENT SIGNAL FROM LEFT FRONT SENSOR.pdf (49.6 KB, 7 views)
