Old 03-27-2013, 06:43 PM
Ahays63's Avatar
Ahays63 Ahays63 is offline
Vehicle: 2014 Dodge Ram
Trim Level: sport
Rep:267
Ahays63 is a jewel in the roughAhays63 is a jewel in the roughAhays63 is a jewel in the rough
Default Need and LED guru
alright so today i put some leds in my cab passenger/driver...i wired them into my dome light also with a switch...works great turning on and off and dimming with the cab lights problem is when i turn on my switch it also turns the dome light back on...is what im wondering if anyone knows a way or peice i could install that will not send power back to the dome light...in other words get power to flow one way? so i can turn only my LEDs on without the dome but yet have them kick on when you open doors and what not? thanks for the help anybody thats smarter than i am!
awww no mods yet due to restarting on a new pick up
Old 03-27-2013, 07:12 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
Only thing I can think of is pick up a relay at the auto parts store and wire it up so when you hit the swith you installed the relay will swith to an alternate battery source.
Old 03-27-2013, 07:44 PM
Ahays63's Avatar
Trim Level: sport
Rep:267
alright any idea exactly how to wire all this up ? im kinda a noob only good at the basics
Old 03-27-2013, 08:10 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Read up on wiring your lights in parallel instead of in series with your switch. It's been since high school but I believe that is the answer. Even then I'm not sure if you can do it or gain access to the wiring to do it. Maybe you should change your title to "Need a wiring guru".
Old 03-27-2013, 08:27 PM
JWM59's Avatar
Rep:148
You somehow allready tapped into you dome light and ran it to a swithch/light and ground. Tell the parts guy what you are up to and he will pick out a relay for you. Once you get it they usually have a wiring diagram etched into it. If you have a 12V supply or battery laying around an Ohm meter and small jumper wires which you can grab at Radio Shack. Than you can play around with it and understand how it works. Kind of a fun project. The side of the relay that is normaly closed will go directly to dome light source you found. The other input will go to the switch you installed and than to 12V source like the battery. Just using battery for an example I would try and find a 12V source that works off the igniton in case you would forget to turn the LED lights off thus draining you battery. Output on the relay goes to LED which goes to ground. Good luck and have fun.
Old 03-27-2013, 09:08 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
You already managed to pull off a good job getting everything wired to the dome and switch. When I do my interior LED's.. I'm gonna take the easy way and wire them up to my switch that I installed to turn on my grill LEDs.
This is something that you may be able to find on google by just spending some time hunting.. There has for sure been someone who has done the same thing before.
IG:@briley59
Old 03-27-2013, 11:45 PM
Ahays63's Avatar
Trim Level: sport
Rep:267
thanks for the input ill give the relay a try and see if i cant play with er enought and get it figured out
