Need help to make sure I have it right - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 03-28-2013, 01:13 AM
parsram parsram is offline
Vehicle: 2012 Ram 1500
Trim Level: ST Express
parsram is on a distinguished road
Smile Need help to make sure I have it right
I have a 2012 ram 1500 to change out the front gears I have to buy the whole front diff are just the carrier I just trying to make sure I have I right before I start buying thing and what about the rear end is there anything different about it are is it still the same as years past
Thanks
Old 03-28-2013, 02:02 AM
Rep:2929
the front & rear gears have to have the same gear ratio
I won't comment on the 2011 or 2012 gear swap
there are many members that can inform you on them, way better than i can
Old 03-28-2013, 02:26 AM
I know that the front and rear have to be the same thanks gtyanee
Old 03-28-2013, 07:53 AM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
I wouldn't think you would have to buy a who dif maybe just the ring gear and pinion.. But aswell I'm no expert
2015 Ram 1500 crew cab 4x4 Hemi
Trailer tow package, timbrens, husky liners, k&n drop in, roll up cover, 14" magnaflow w/4" stainless tip, LED bedlights, led reverse pods, 2" HBS, Bfg KO2
Old 03-28-2013, 12:01 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Yes, on a 2012 you need to buy a front diff from a 2011 in order to change the gears. They welded the gears in on a '12 so it's not possible to change them. fastNugly@discountautoperformance has done the gear change and would be able to help you out as far as what's all involved. I think he said you'd be looking at around $3600 to do the full swap.
