Old 03-28-2013, 09:26 AM
missy missy is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: Thunder road
missy is on a distinguished road
Default After Lift, Possible Problem? Need Help.
Hey Guys,
I have a 2005 Ram 1500 quad cab. Automatic, 5.7 Need some help and advice on what to check.
My truck is lifted with 3"'s of body and 3"'s of suspension.
It feels like the rearend is moving or shifting when taking off from a stop.
Is this normal after lifting? I have 3" blocks in the rear and new u-bolts back there. Torsion bars in front have new re-indexed keys. We have the pinion shims in too. I have the truck almost level front to rear, and the truck has been aligned. Not sure what to check first. Any advice?
Thanks, Missy
Old 03-28-2013, 11:34 AM
Rep:1845
The first thing to do is to double check and make sure all the suspension components are properly torqued with zero preload on any of the bushings.
