Old 03-28-2013, 12:58 PM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Default R/T Towing Capacity..
Does anyone have the information from "RAM" for the lower towing capacity on the R/T?
Our trailer weight is ~ 5000lbs, where as the same truck, (Express), with 3.92 gears is over 9000lbs.
Just curious.
Rear Springs?
Torque Converter?
22" Wheels / Tires?
David
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Bak Flip "VP" Tonneau Cover, Oil Catch Can
Old 03-28-2013, 01:12 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Can't say why you are limited to 5050lbs max tow, but by the looks of the specs on rambodybuilder a portion of the reduction is likely due to stance of the truck and the axle weight distribution where you are closer to 50/50 than the same express which has more rake in the stance therefore transferring slightly more weight to the front axle.
Spring rate is likely a factor as well.
Hope somebody chimes in and has a better answer, interested to know as well.
Old 03-28-2013, 04:12 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Typically, a performance truck (or car for that matter) from the factory with a lower then standard suspension will have a lower towing capacity due to the reduced suspension travel.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 04-01-2013, 10:07 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Check here: http://www.ramtrucks.com/en/towing_guide/
I assume yours would fall under the Sport with the 4.10 gears. 5,050lbs.
Old 04-02-2013, 04:19 PM
TriSum's Avatar
Trim Level: R/T
Rep:47
I know what the limits are. I want to know why is the Sport / RT is lower than the regular Express at 9000 lbs.
David
2012 R/T
Old 04-02-2013, 08:01 PM
Color: Black (PX8)
Rep:388
Sorry. Like the others said I would say springs and tires would have a lot to do with it.
Old 04-03-2013, 01:35 AM
TriSum's Avatar
Trim Level: R/T
Rep:47
OK, doing some research and it is not the tires. Most of the stock 20" size tires are rated at 2601 max psi, (some are more), and the stock 22" tires are 2601 max psi, (some are less), but for the most part they are rated the same.
Payload is almost the same also, Express with 3.92's is 1493 lbs and the R/T is 1412 lbs. So, this would be the difference of the rear springs because this takes into account any tongue weight.
Obviously it's not the gears because the R/T would be rated higher with 4.10's than the 3.92's.
So what's left, transmission and torque converter. ??????
More interesting info:
Transmission 1500 Ram w/ 4.10 gears. Part # RL087046AB
$3333.33
Transmission 1500 Ram w/o 4.10 gears. Part # RL051225AD
$4270.00
Hmmm.....
2012 R/T
Old 04-03-2013, 01:53 AM
Rep:2657
it all has to do with Curb Weight, empty vehicle
Wheel & tire weight
Bumper weight
radio weight
seat weight
The more the weight of an empty vehicle, the less it can tow or haul
17 inch tires are lighter then 20"
aluminum is lighter then steel
etc.
Old 04-03-2013, 10:49 AM
Color: Black (PX8)
Rep:388
Does the R/T have the heavy duty oil and tranny cooler?
Old 04-03-2013, 12:55 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's the higher stall rpm on the torque converter. Higher stall rpm causes more heat build up, especially when under load.
If you buy an aftermarket high stall TC the manufacturer will advise you not to tow.
Sean
