Old 03-28-2013, 06:07 PM
Alberto22's Avatar
Alberto22 Alberto22 is offline
Vehicle: 2011 ram 1500 quad cab
Color: Deep water blue Pearl
Rep:72
Alberto22 will become famous soon enough
Default pinion factor reset
So today i went to the dealership for an oil change. When i got in the garage the dude looked over the truck and said you have larger tires then stock. Yes i do there an inch taller. When I went in the service office they told me since my tires were larger then stock I need to have A PINION FACTOR RESET so the speedo will read correct. My speedo is off by 2 mph at most. I said OK do it (thinking its covered). Then she tells me it's $130 to do, my answer is forget it i can live with the speedo off by a little. At which point I was told that if it wasn't done my transmission might suffer and fail and not be covered. Seriously?!?!?!?!? Is this true???? I find it hard to believe tires taller by 1 inch will send my transmission into a downward spiral and not be covered. Am I right or wrong?
stock tires 275 60 r20
new tires 275 65 r 20
The best way to a fisherman's heart is through his fly!
MODS. f1 bakflip, rain guards, Mopar bug deflector, husky floor liners, chrome gas cover, westin side steps,steal craft brush guard,Piaa fog lights, painted calipers, sport hood, KENWOOD EXCELON DNX9980HD with cmos 300 camera, Magnaflow 14"
Old 03-28-2013, 07:24 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
So if your tires were 1" shorter the trans would last twice as long?
They are trying to get you to part with $130 for nothing.
Find another dealer if possible.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 03-29-2013, 06:34 PM
oldhp's Avatar
Color: WHITE
Rep:902
I measured my snow tires, they are 1"+ taller.
Have run over 2K miles this winter with no issues.
Old 03-29-2013, 09:51 PM
Alberto22's Avatar
Rep:72
I think Im just gunna chance it.
Old 03-30-2013, 04:25 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
$130? Does it take a couple hours to do this? Seems a bit pricey. I mean for a few hundred more you could get a tuner and input the size of the tires......plus get a ton more bugs worked out.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 03-30-2013, 08:07 PM
Alberto22's Avatar
Rep:72
still on the fence on what I should do.
Old 03-30-2013, 10:13 PM
OAG18 OAG18 is offline
Vehicle: 2013 Ram 1500 4x4 cc
Color: Maximum Steel
OAG18 is on a distinguished road
Absolutely nothing at that price! I doubt it would even be 2mph off and he is lying to you about it hurting the transmission. It takes me 5 min. to recal my speedo with mt tuner. He is looking to rip you off! I would never use them again and tell them why! By the way I doubt they are even an inch bigger.
Old 03-31-2013, 08:51 AM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
My tires are also taller by an inch and I had the dealer do the adjustment. It only takes a few minutes, even easier if they are already connected for some kind of update to your computer. I'd find another dealer as $130 is raping you big time if you want it corrected. Nothing will happen from not changing the size for an inch, just the speedo and odometer will both read a little low. I wanted mine correct though as the truck was brand new so I had the tire size changed.
Comparing the 2 sizes shows his new tires to be 1.1" taller or a difference of 3.3%. So at 55 mph, the speedo should read less than 2 mph slow. Nothing that would do any damage. But personally something I would want adjusted, especially if that was the tire size I planned on sticking with. If they were just winter tires though, I would not mess with the adjustment.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 04-02-2013, 12:32 PM
oldhp's Avatar
Color: WHITE
Rep:902
Here's another reason; your mileage will show less than what is really on the truck. If you have 100K warranty, now you have 103,300 warranty with the 3.3% difference in tire size.
