Old 03-28-2013, 09:12 PM
jtf1967 jtf1967 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Tradesman Edition
Color: Grey
jtf1967 is on a distinguished road
Default electric cooling fan
I'm thinking about removing the mech. fan and replacing with electric cooling fan. Was wondering if anyone has done this and which fan would be best.
Old 03-28-2013, 10:49 PM
I push the skinny pedal
Rep:3277
It's been done many times and there are several writeups about it if you use the search function. Most people use the V6 electric fan with a generic e-fan controller.
Kurtis
Old 04-02-2013, 11:39 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i thought our trucks came with electric fan from the factory.
Old 04-03-2013, 12:37 AM
Moose612 Moose612 is offline
Vehicle: 2006 Ram 2500
Rep:26
Moose612 is on a distinguished road
The V-6 does and thats the one I've read most people are using. It can then be controlled via a diablosport. The V-8 crank driven fan.
Living the dream.
Old 04-04-2013, 04:36 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Yes they do for the V8. I learned that recently. Only for AC use. The belt driven clutch fan does the normal cooling.
Old 04-22-2013, 11:31 AM
Bgrthnurhemi Bgrthnurhemi is offline
Vehicle: 2011 dodge ram
Bgrthnurhemi is on a distinguished road
Yes. The V6 fan found on 4th gen 1500's with the V6 is the easiest fan to swap in. I have a 2011 1500 Hemi and did the swap about 3 months ago. Its completely plug and play. No wires to splice and pushes air well. I installed a 180 degree thermostat and I think Hemifever set my diablo to have the fan come on at 190 degrees.
I have yet to tow in the summer with the v6 fan, but plan to do so this summer. We will see how it cools down the truck in 105 degrees and humidity in Oklahoma.
Old 04-22-2013, 02:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
To clarify....
The 4th gens (not just the v6's) have an electric cooling fan from the factory. The v6 electric fan is nearly identical to the v8 electric fan. It actually is identical from what I can tell except for the shroud. I don't see the benefits of swapping to a v6 efan as being worth the cost. It will be slightly better as the shroud is slightly better but the stock fan cools ok without the mechanical fan and adjusting the settings(I've done it).
I believe stock programming, the efan on the v8's only kicks on at 222 deg F or higher (overheating protection).
Sean
Old 04-24-2013, 06:56 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
I just removed the clutch fan and used my diablo to set my stock e-fan to come on at 190 works great and didn't cost anything.
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-29-2013, 08:58 PM
Eagledriver Eagledriver is offline
Vehicle: Dodge ram 4x4
Trim Level: 2500
Color: WH/BLK
Eagledriver is on a distinguished road
id like to do this mod next...great info
Old 06-27-2013, 01:21 PM
Munki63 Munki63 is offline
Vehicle: 2011 Ram
Munki63 is on a distinguished road
what do you gain with this mod?
