Old 03-29-2013, 12:01 AM
balloo balloo is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Club cab
Rep:12
balloo is on a distinguished road
Default Four Wheel Drive - - LOW
I have never needed to use the FWD, so today I thought I would check it out.
Had tranny in neutral before turning the switch.
FWD LOW appeared on the dash, as well as Stability Control Off.
Drove about block. Stopped, and when I stared to move it felt like the tranny was looking for the correct gear.
Stopped again, and the same thing.
Once moving all seemd okay, and truck shifted up as normal.
I only drove less than a mile.
Is this normal ?
Thanks,
Old 03-29-2013, 12:45 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
You did this on pavement, correct? 4lo behaves differently then 4hi and I wouldn't be surprised it felt funny especially if running 4lo on pavement. Now, does it do the same thing when in 4hi?
Kurtis
Old 03-29-2013, 01:57 AM
Rep:12
YOU ARE RIGHT !, yes, I was on pavement. And no it does not do this when in FWD HI.
Just came up with another question: Does FWD, LOW, prevent the tranny from shifting up to 6th gear.
And Yeh, I know - - you are wondering why I bought FWD. Well one reason is that my wife will use it to pull a horse trailer, and got my old truck stuck in mud twice (that I know of), also in most cases it will keep me from having to put chains on when going over the mountains in the winter.
Cheers, and thanks,
Balloo
Old 03-29-2013, 08:16 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
First I would not run your truck on dry pavement in 4 wheel drive either HI or Low. Lo per the user manual states: 4L
Four-Wheel Drive Low Range - This range locks the front
and rear driveshafts together forcing the front and rear
wheels to rotate at the same speed. Additional traction
and maximum pulling power for loose, slippery road
surfaces only. Do not exceed 25 mph (40 km/h).
Now if you have 4 Auto it is not going to hurt to run on pavement but if it is clear I don't see the need.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 03-29-2013, 09:08 AM
Asur Asur is offline
Vehicle: .
Rep:4371
What he said ^^^^^^^^^^^^^^^ pavement will kill your Transfer Case and other parts.
Old 03-29-2013, 09:16 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Is this normal ?
Thanks,
You are very lucky you diidn't snap one of your front axles when you went around the block The only time you should ever use your 4WD whether in Low or High range is on a loose surface like gravel or slippery conditions. And your using the wrong acronym for your truck "FWD" describes a "front wheel drive".
Old 03-29-2013, 08:16 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
Cheers, and thanks,
Balloo
Oh MAN! Not trying to bust on you, but are you really thinking you would ever get to 6th gear in 4-low? You would probably never even reach 3rd. 25 MPH max in 4-low. Just trying to save your drivetrain.
Old 03-29-2013, 09:49 PM
Rep:3277
Yeah, you should never even attempt to get to 6th in 4lo. The transmission doesn't lock anything out, but you'd start breaking stuff if you tried running it that high.
As for running in 4hi on pavement, it can be done, but not recommended for long periods. the comment about breaking axles is wrong, in hi or lo. The drag racing crowd makes bigger power and runs down the entire track in 4wd with no issues in the transfer case.
Kurtis
Old 03-29-2013, 10:59 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
But they are going straight, not turning around the block.
And the ones I know who do that, have aftermarket axleshafts....not stock.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 03-30-2013, 01:52 AM
Rep:12
Thanks to everyone !- - this just goes to show, that there is no such thing as a "stupid question", cause you nice folks are all willing to provide excellent input.
Cheers,
Balloo
