Old 03-29-2013, 12:07 AM
blackmamba2012's Avatar
blackmamba2012 blackmamba2012 is offline
Vehicle: 2012 ram 1500 express
Trim Level: express
blackmamba2012 is on a distinguished road
Default offroad tire sizes
I've been told so many diffrent things about tires and whether they will fit my rim. I have a 2012 express with the upraded rim 20x9 i belive the same ones as the sports that year i was told that a 35x12.50r20 will not fit on my rim is this true if it is whats the biggest size i can fit on the rim the truck is lifted and i am putting a 1/4 wheel spacer
Old 03-29-2013, 12:35 AM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
As far as I know there should be no issues. Buddy of mine had 35's on his '12 rcsb sport with stock rims and leveled. Runs 37's on them now with a full lift and wheel spacers I believe. I've seen lots of other trucks on here with 35's and stock 20's as well.
What lift are you running? Your truck is 4x4 correct?
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 03-29-2013, 02:21 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yup. You can run 35x12.5's on the stock 20x9's with a 1/4" spacer (provided you have a 2.5" level or lift). Tons of guys on the forum do it. You might have a bit of rubbing at full lock but that would be it.
Old 03-29-2013, 04:10 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:62
I have seen rams with a 4" rcx lift with 35x12.5 on stock 20" Laramie wheels.
Old 03-29-2013, 08:40 AM
Grubrunner's Avatar
Rep:3883
Are you concerned about light or any rubbing at full steering lock? What 35x12.50R20 tire are you specifically speaking of? An AT or an MT? What lift/level do you have?
They will fit HOWEVER the tire's aggressiveness may be the deciding ..... dependant on the lift you have.
I highly doubt whether an aggressive tire like a Mud Terrain will fit on the OEM rims even with the spacer..... dependant on the lift you have.
You get the point.
Grub out!
Old 03-29-2013, 09:30 PM
Trim Level: express
i plan on buying 35x12.50r20 nitto trail grappler or toyo open country mt i have 5100 blistein with 2.5 lift and 3 in bodylift
Old 03-29-2013, 10:39 PM
Rep:2026
You definitely won't have a problem with that set up. You'll just need the 1/4" spacers to clear the UCA
Old 03-29-2013, 11:50 PM
Trim Level: express
thank you I've been putting the order off now for about two weeks due to all the conflicting answers from tire dealers I'm deciding just to order the nittos and see what happens does anyone recommend a spacer brand any help is appreciated
Old 03-30-2013, 12:27 AM
Rep:2026
Where are you getting the body lift from? Lots of times the lift companies make spacers. At least just 1/4" ones. I know Rough Country does for sure.
Old 03-30-2013, 12:33 AM
Trim Level: express
I'm getting the performance accessory http://www.performanceaccessories.com/details.php ?Application=Dodge&Part_Number=60203&Title=DODGE%2 0RAM%201500%202%20&%204WD%20GAS%20ENGINE&Active=Ye s&Category=Body%20Lift%20Kits
