Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 03-29-2013, 10:41 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
Question umm not sure what to think of this problem
i have an 07 pw and last night i tried using the diff locks and couldnt get them to engage, and i tried the sway bar disconnect and all the button did on the dash was flash orange. am i missing something to get the systems to work? i tried them both in 4hi an 4lo and couldnt get them to operate
Old 03-29-2013, 11:26 AM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
Not sure how to help except to take it somewhere to be looked at or look yourself. Just another example of why electronics and offroading do not mix well. If U can convert things to a manual lever where U actually/physically move the part yourself U will be better off. Good luck.
Old 03-29-2013, 11:39 AM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
It has to be in 4 lo for them to be engaged - the rear locker has to engage before the front is allowed to engage. Sometimes you will have to drive 2-3 mph and make a turn or two for it to lock in - the spindles have to align properly for it too lock. The front sway bar is the same way - turn it on and drive slowly making a couple of turns. The sway bar will also automatically relink itself over 20 mph (or close to it). If none of this works it is time to have it looked at - there are some mods on this site to make this stuff work a easier and have more latitude in when you can use them - I havent tried the mods yet as I am afraid of voiding the warranty but I havent had any issues with the lockers or sway bar yet.
Old 03-29-2013, 02:26 PM
Rep:68
thanks guys i will be trying again today
Old 03-30-2013, 09:27 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
Make sure your in 4 lo before engaging lockers and sway bar disconnect and then drive forward going left to right afew hundred feet and then everything should lock up and disconnect and its very hard from them to disconnect and lock up if your on a hard surface as oppose to gravel-dirt-snow-mud... as slippery surfaces allow them to lock up better and that's what I do to loc up mine.. and I have an 2006
Smile even if its a little creepy
Old 04-11-2013, 05:48 PM
Rep:68
ok i tried again today but no luck with the diffs. they wont lock. not that it matters much with both diffs being limited slip. its hard as hell to turn at all in 4wd on this thing on the street. but im not sure if the sway bar disconnect is working. by these pics what do you guys think? and yes just in case your wondering the hood scoops add 10 hp..... lol[IMG][/IMG] and oh yea i got
Old 04-11-2013, 05:49 PM
Rep:68
this is the other pic i tried to upload but it wouldnt let me
Old 04-11-2013, 06:32 PM
Sledlvr's Avatar
Sledlvr Sledlvr is offline
Vehicle: 2012 Powerwagon
Color: Black/Red
Rep:29
Sledlvr is on a distinguished road
i would say it's not disconnecting , lol, check your relays and fuses
37x12.50 17' Super Swampers , HID's, Bullydog tuner,Catch can,Volant Powercore CAI, 4" Dynomax exhaustfor a 6.7 diesel, Kenwood TM271 65w VHF radio,240mm Lightforce Blitz HID driving lights,Custom 8'x9' aluminum sled deck
Old 04-11-2013, 08:35 PM
Rep:26
I think its your Switch since its all connected... if your not in 4-Lo then its not going to work ........... By the last picture shows that they are NOT disconnected....because the front right tire should be up in the wheel well and the right back tire should be on the ground... so therefore the sway bar isn't disconnected...
http://oica.net/wp-content/uploads/2..._wagon_lpg.jpg
Do you see how the Rear tire is far up inside the housing and the front tire is bowing inward... that's a sign of the Sway bar disconnection...
Old 04-12-2013, 02:13 AM
Rep:68
thats what i figured. i tried everything to get it to disconnect but it wont. i think i may have to start unplugging the harnesses and check for power after i check the fuses and relays
