Old 03-29-2013, 07:06 PM
deadbug deadbug is offline
Vehicle: 2013 RAM SPORT
Trim Level: SPORT
Color: BLACK
Rep:31
deadbug is on a distinguished road
Default Coolant temps ?
Next time you guys are running around in truck take a look at what your coolant temps are and could you please tell me what your seeing and what outside temps are. I'm coming out of a 2011 CTD and the hemi seems to be running alot warmer on average, just trying to see if my temps are normal
i'll update my sig as well, but i have a 2013 sport 5.7 3.55 all stock
Tia...
Old 03-29-2013, 07:11 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
What temps are you running?
Old 03-29-2013, 07:20 PM
Trim Level: SPORT
Color: BLACK
Rep:31
upwards of 210 the 3500 CTD was pretty solid around 203 and I thought the hemi had a 200 degree t stat as well and figured it should be the same.
I only have 250 miles but i dont think that has anything to do with it,
Thats coolant not oil or trans!
Old 03-29-2013, 07:35 PM
Rep:160
I think it's a 203 f thermostat stock, I see those numbers, lately around the 200 f mark, my oil runs around 205 f and my trans, I am usually seeing 160 f give or take.
Old 03-29-2013, 07:57 PM
Trim Level: SPORT
Color: BLACK
Rep:31
Thanks Otterdriver,
Old 03-29-2013, 08:17 PM
Rep:2616
Apparently the 2013 Ram engineers decided that the automatic transmission operates most efficiently at 190 degrees F
Here is a video telling about the new Thermal Management system
http://www.ramtrucks.com/en/2013/ram...photos_videos/
In our pursuit for efficiency there are less obvious things. One is thermal management.
The engine and transmission oil is most efficient at 190 degrees. But unless the truck is operating at max capability, the oil never gets that warm.
Thermal management heats the oil, so even during everyday use, it reaches 190 degrees.
Old 03-29-2013, 08:25 PM
Rep:160
I see above 200 degrees F for oil temp on a regular basis, I suppose it's where it's supposed to be. I'll be interested to see what temp I get in the middle of summer pulling my trailer. Unless someone says it's detrimental, I am going to go for the 180 thermostat,although I don't see that being a problem.
Old 03-31-2013, 02:26 AM
MeanieNJ MeanieNJ is offline
Vehicle: 2013 Ram
MeanieNJ is on a distinguished road
I see 200-210 regularly. My instincts tell me to put a cooler stat in... but my brain says they would have done that form the factory if it would be better. Im gunna leave it alone for now.
Old 03-31-2013, 09:09 AM
Rep:160
Same here, I'll wait til it warms up to see what happens.
