Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 04-09-2013, 01:56 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Yes, I suggest you change your plugs to a heat range colder than stock. Also get a custom nitrous tune from Sean Powell at HemiFever. And run 93 octane fuel. My tune is a factory tune with timing pulled. My kit is from nitrous outlet. Ill send you a link in a bit. I purchased from Matt at moesperformance. It's a wet kit, and I also purchased the accessory package. And HELL YES IT'S WORTH IT. Such a good investment. My tranny is doing fine so far
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 04-09-2013, 01:57 AM
Color: Gloss Black
Rep:141
I'm not spraying off the line but I am spraying through shifts so my trans is probably working a bit harder than usual. Just don't make consecutive runs and you should be fine. I'm getting a widow switch to help that problem. I'm running a Wot switch right now
Old 04-09-2013, 08:56 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You should give him the plug info.
Anything more than a 50 shot and you should probably go to a colder plug, colder tstat, etc. And I wouldn't use a dry kit on something you want to stay reliable.
Sean
Old 04-17-2013, 11:10 PM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
For every 100 HP gained you need one step colder plugs, you might want to look into Brisk non projected tip plugs
I have run a nozzle, plate, and now a direct port and for those who love spray, its the way to go. I would say you could hit it with a 125 shot on a stock block but wouldnt go higher... I would switch to one step cooler, and maybe add a little race gas to help with KR
My Mopar Stable: 07 SRT8 Charger 426 Stroker with Direct Port Nitrous (1/4 9.70@138.88mph)'
2011 Dodge Durango Crew 5.7L Hemi / Custom Katskinz
2012 Chrylser SRT8 300 optioned Out
2011 Ram 3500 SLT Big Horn Dually
Old 04-19-2013, 12:05 AM
ramnher's Avatar
ramnher ramnher is offline
Vehicle: 2008 dodge ram 1500 4.7L
Trim Level: st
Color: metallic grey
ramnher is on a distinguished road
Awesome! Thanks for all the info guys! Dark night if you remember any more info on the plugs deffinatley let me know. Think I'll just run a 125 wet shot in the cai, shot on a one range colder plugs and get my tune from the hemi fever you talked about.
U mirin bro?best(0-60)time 6.31.best(1/4)mile time 14.89.2008 dodge ram 4.7
Old 04-22-2013, 09:38 AM
snrusnak's Avatar
Rep:1385
PM darknight, he doesn't get on a whole lot but has the plug info I know for sure.
Sean
Old 04-30-2013, 06:50 PM
ramnher's Avatar
Trim Level: st
Alright I will thanks!
Old 05-05-2013, 02:18 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Update the thread when you find out please.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 05-10-2013, 09:08 PM
ramnher's Avatar
Trim Level: st
Still waiting on him bro I will tho
Old 05-13-2013, 10:18 AM
snrusnak's Avatar
Rep:1385
I emailed him for you guys...
Sean
