Old 03-30-2013, 01:00 PM
VanillaHemi07's Avatar
VanillaHemi07 VanillaHemi07 is offline
Vehicle: 2007 RAM 1500
Color: Cool Vanilla
Rep:15
VanillaHemi07 is on a distinguished road
Default What size wheel adapter do I need?!!
My current rims are +25 offset. I like the rims, so I don't want to get new rims if I don't have to. My question is: What size wheel adapter will I need to get the look of a -12 offset rim? Something like a 1"-1.5" adapter? I am running 295/60/20 Trail Grapplers with a 1/4" wheel spacer right now. They are rubbing when turning, not bad, but they are. I would really like the look of a 0 offset or a -12 offset. Either look would be great. Also, what are you guys thoughts on wheel adapters?
2007 RAM, 4x4, 2" HBS Level, Eagle Alloy 050 Rims, 34" Nittos, K&N Filter, Flowmaster Exhaust
Old 03-30-2013, 11:58 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
To get to a negative twelve offset stance from your +25 stance, you need a 1.5" spacer. To get to a zero offset, you need a 1" spacer.
Simon
Old 03-31-2013, 12:10 AM
Color: Cool Vanilla
Rep:15
Thank you, that's what I needed to know. Have you heard any negatives about running adapters? Are they safe to run?
Old 04-01-2013, 06:10 PM
LowUFO's Avatar
Rep:1109
Oh yeah. But the thickest spacer you can run on the stock studs is 1/4". Thick spacers like 1" plus, make sure you get them with their own studs pressed into them for your wheels to sit on. Buy decent quality ones. 1.5" like Motorsport tech B.O.R.A. ( http://www.motorsport-tech.com/special/truck/dodge_s )
I've run them on various vehicles and never had an issue. Make sure to get hubcentric like the MT ones (which means it has a flange around the center for the wheel to sit on instead of the wheel just sitting on the studs and not being perfectly centered.) to help eliminate any front wheel shimmy around 60mph.
You have to take a wheel off first to see if there is relief area on the backside of the rim for the stock stud ends to sit in because they are 1.75" in length I believe. You can measure your studs when you take the wheel off to verify this. If there isn't any relief on the back of the rim for the excess stud when it protrudes through your new spacers, you'll have to cut off a quarter inch (if they are 1.75" and you buy 1.5" spacers) off the stock studs so that your rims sit tight up against your new spacers.
Simon
Old 04-01-2013, 08:06 PM
Color: Cool Vanilla
Rep:15
Thanks for the info. Gonna call my local shop, see if they have what I need, if not, will order. Thanks again!!
Old 04-01-2013, 11:03 PM
LowUFO's Avatar
Rep:1109
No problem. Good luck. And post pics before and after for us to see!
Simon
Old 04-17-2013, 10:22 PM
Color: Cool Vanilla
Rep:15
Wheel Adapters are on & posted pics in another thread: "A Couple of New Mods".
