Old 03-30-2013, 04:01 PM
jivy26 jivy26 is offline
Vehicle: 2004 Dodge Ram
jivy26 is on a distinguished road
Default Need Help! Starter, start terminal lead.
Had some issue removing the terminal from the starter. Once i got it off everything was easy. I'm trying to plug the terminal into the new starter, but no amount of pressure will budge it to completely lock into the connector. I have also tried connecting it to the old starter and I have the same issue. I think it is the terminal lead cable that got messed up when I disconnected it initially? I've included a picture of both the terminal cable and the connector on the starter so that maybe someone will see a issue and help out.
If I'm calling the cable the wrong name i apologize. It's the cable coming directly from + connection on the battery to the starter.
If you're wondering why cable is on top of the engine i disengaged the clamp holding it to the frame.
Thanks for any help.
Old 04-01-2013, 09:26 PM
02Kingstonram's Avatar
02Kingstonram 02Kingstonram is offline
Vehicle: 2002 Dodge Ram
02Kingstonram is on a distinguished road
Here's what I get when trying to open the pictures.............."Error (403)
It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home."
