Old 03-30-2013, 10:20 PM
Chris65 Chris65 is offline
Vehicle: 2007 Dodge Ram
Color: silver
Rep:45
Chris65 is on a distinguished road
Question Right side flasher fast,front and rear works
Hey guys, I'm new here and found this forum in google.
because I was a active member in a motorcycle forum, I know, that this can be a powerful tool to be happy and stay happy with your vehicle.
I have following problem and I hope somebody can help me with troubleshooting:
I just bought a used 2007 Ram Quard Cab 4.7L
As I bought the truck, I asked the sales guy about the flasher right side.
The left side works fine, the right side flashes fast. Front and rear was working, just faster. The sales guy told me, that this might be a bulb, because they having sometimes high resistance in the socket.
I am car technician and well...- I know that happens. So I bought the truck.
Today I checked the blinker and found the horror.
After removing both headlights, I found, that somebody connected per hanging wire the right head light with the right head light. The wires was just drilled together and taped. the left headlight connector is already slightly overheated.
I found the wires from the left headlight in the plastick pipe. I bought 2 new connectors and connected it to the original wires. The wires was dead.
Now it started getting weired. I checked under the dash and found non-original wiring, 3 wires from the OBD-Connecto wires was capped and routed in a aftermarked wiring harness. I removed all covers left side and found on top of the kombi under the trim a power commander.
Beside I hate these useless wannabe improvement tries, everything was rednecked together like a 15 year old would do.
I followed the wires from the light switch and it seems like they go in direction kombi instrument.
Now my question: does anybody knows how the light wiring is routed?, is the light module integrated into the kombi instrument? can it be that by trying to do professional work done by a dummy the light module got shot?
I was not going further, because I called the dealer. Monday I will show him the mess. He already told me that he does not want to take the car back, but I will try to get some money back. I don't trust anybody anyway- seen too much. I know I can do it by my self, just need the information and maybe a wiring diagram.
Does anybody knows, what a new light module or kombi instrument would cost, if it's shot?
Need to know how much I can tell the guy I want back.
He told me that his technicians checked the car- but if somebody would had checked it, he would have seen, that it is even very dangerous to run 2 headlights on one 0.5mm wire. My oppinion is, he should not had sold the car this way.
Like I said, I just found out after I checked the lights by my self. the wire from the right to the left headlight was hidden in the front bracket and not visilbe on first sight.
Or did anybody had this issue before?
I would be happy if I could solve the problem.
Thanks!
Old 03-30-2013, 11:34 PM
I push the skinny pedal
Rep:3277
All the lights are controlled by the TIPM. I actually shorted out my passenger side low beam on my '07 and had to run a relay off of the driver side to make it work unless I replaced the entire TIPM.
When they do vehicle safety inspections they don't remove things like the headlights, they just ensure lights blink and turn-on when required. This could quite easily have been overlooked if they just did a safety inspection. Did you buy from a Chrysler dealership or just a used vehicle lot?
Kurtis
Old 03-31-2013, 10:44 AM
Color: silver
Rep:45
Thumbs up
Thanks a lot.
That's what I figured. I know that the newer models getting the signal from the flasher switch and the light switch into the Kombi. I know from VW Audi that the Light control module is in the Kombi.
Because the flasher issue and the light issue, I thought they are 2 independend issues or one big issue.
I also found out that the Module cost around $650 in e-bay. I would go safe and see if I can get a Kombi too, remove the dashboard, disable the chip tuning and get everything back to original.
I estimated a cost frame of $1200 - $1500 if I let somebody do it.
But...I don't trust nobody in repairing a car professional. Seen so much- on my charger they put the wheels on with impact wrench regardless there are chromed aluminum lug nuts and they destroyed them. and on my Beamer they was not even able to make a oil chage without stripping the thread in the oil pan and removing the oil filter before draining the oil.
The dealer was a car lot but he has a shop too. He told me his technicians checked the car and they haven't seen it. well I tolld him he better get some technicians and send the wannabe's home.
I hope to get at least $1000 out of him.
Thank you for your answer. helped a lot - realy.
Chris
