Wheel Stuck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-31-2013, 03:24 PM
maldo321 maldo321 is offline
maldo321 is on a distinguished road
Default Wheel Stuck
I had to change my 2010 1500 Ram's wheel. I took out all the screws and when trying to pull out the wheel, It is completely stuck. I've check the manual, Youtube videos and nothing. Anything that could help?
Old 03-31-2013, 03:33 PM
CherryRedHemi CherryRedHemi is offline
Vehicle: 2015 Ram Rebel
Trim Level: Rebel
Rep:15
CherryRedHemi is on a distinguished road
I'm guessing you probably live in a northern state with salt and what not on the roads? Basically your going to have to force it off by various means. I had the same problem on my previous truck when it was new, I believe I used a mallet and basically try to rock the wheel back and forth to try to break it free, make sure you have it on some jack stands while doing this though. Ever since then I take a little bit of grease and put it on the hub where wheel seats onto, it will make it easier to remove in the future, just make sure not to get any grease on the threads of the wheel studs.
Old 03-31-2013, 03:41 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Kick the edge of the wheel one good time and jar it loose
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 04-01-2013, 04:37 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Yep, works every time. just be sure the truck is on jackstands and not just a jack.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 04-01-2013, 06:55 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Yup, that is what is needed.
it doesn't take much, just enough to "break the seal"
Exco
Bill
Old 04-01-2013, 05:30 PM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
One trick my dad uses is to back the nuts off a bit then rock the vehicle for wheels that are really stuck.
Old 04-01-2013, 07:18 PM
Outlaw's Avatar
Color: Bright white
Rep:435
That could work but it'd be easy to fubar a stud that way.
[/CENTER]
Old 04-02-2013, 02:17 PM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:49
2010x3.92 is on a distinguished road
The rocking is a great idea. Never thought of that but you can really get some serious force that way..
Last weekend I rotated my tires after all winter. Every wheel was stuck. Rubber mallets won't really get the job done. Get a 2x4 wood and just smack the wheel itself with the wood between the hammer and the wheel. Get a hammer that has a pretty good mass and you won't have to hit it very hard.
Use a wire wheel or abrasive wheel made for aluminum to knock off the corrosion on the wheel mounting face and apply a thin coating of anti seize. Make sure to put it around the center part of the wheel that fits over the axle. This is where it mostly gets stuck.
Old 04-02-2013, 04:38 PM
Ballentx462's Avatar
Ballentx462 Ballentx462 is offline
Vehicle: 2009 Dodge Ram cc
Trim Level: Lonestar
Color: Grey
Ballentx462 is on a distinguished road
Same thing happened to me a couple days ago. I just kicked them a few times and it broke loose.
Old 04-02-2013, 05:14 PM
Outlaw's Avatar
Color: Bright white
Rep:435
I wouldn't do the rocking trick. Otherwise you'd be back on here asking how to replace studs.
[/CENTER]
