Old 03-31-2013, 05:07 PM
RcsbHemi's Avatar
RcsbHemi RcsbHemi is offline
Vehicle: 2010 Ram Rcsb
Trim Level: SLT 4x4 3.92
Color: PDM Metallic Gray
Rep:32
RcsbHemi is on a distinguished road
Default Check your Volant filter!
I was doing my usual under hood check and decided to check my air filter. I found it just sitting in the air box, who knows for how long. I know it was tight, so check yours to be safe. I just did a little reading and it seems this is a common problem with Volant intakes. I have been looking at the s&b, this may be the push i need to buy one
Mods: Magnaflow DOD14(resonator removed) line-x, tint, silverstars, tonno pro trifold tonneau, LED Licence plate and reverse bulbs, 2- 27w led fog lights behind grille. more to come........
Old 03-31-2013, 07:49 PM
thunder98110's Avatar
thunder98110 thunder98110 is offline
Vehicle: 2012 Dodge Ram
Trim Level: ST express
Rep:14
thunder98110 is on a distinguished road
Ive had the same problem with my k&n
2012 RCSB, Hemi,3.92,2wd,Fastman TB,180tstat,K&N CAI,AeroTurbine 3030xl + Magnaflow Y,v6efan, LEER 100xl
Old 09-24-2013, 09:26 PM
glaizinman glaizinman is offline
Vehicle: 2007 dodge ram 1500 4x4
Trim Level: laramie
Color: black peral
glaizinman is on a distinguished road
Thankyou for the post. I installed a Volant cia on my 07 hemi about a month ago after reading your post today I went out and checked mine . And it was laying there in the box and was not connected!
Old 09-24-2013, 09:45 PM
I push the skinny pedal
Rep:3277
I had the filter on my airaid fall off as well. You need to tighten it down, drive for a bit and then retighten it. Since I do a complete underhood check every second fill up it became something I'd look at when I did fluid and exhaust bolt checks.
Kurtis
