Gears - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-31-2013, 08:57 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Gears
How much would it be to change my 3.55 gears to 3.92 or 4.10 gears?
Old 03-31-2013, 09:34 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Do you have a 4x4 or a 4x2?
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 03-31-2013, 10:18 PM
Trim Level: express
Rep:43
2012 express 4X4
Old 03-31-2013, 10:37 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Ok, what size tires are you going to try running?
If you were going to go through the expense of a gear swap I would do either 4.10's or 4.56's probably 4.56's if you plan on running larger tires, if you plan on staying somewhere around the factory height 4.10's would be ok, but I would still do the 4.56's that is just my opinion.
You are going to need to get a front gear housing out of a 2010 or 2011, and then you are going to need to work with a shop that doesn't mind machining or working with a machine shop. Most will spend around 2k for a complete gear swap sometimes even a little more. fastNugly has some great info on doing a gear swap on 2012's as he has done it to his truck with 4.56's. Check out his build thread for more info, I forgot what page it was but somewhere around 175 I think.
Thanks
Jeremiah
Old 05-02-2013, 04:18 AM
chadob69's Avatar
chadob69 chadob69 is offline
Vehicle: 2009 Dodge Ram 2WD
Color: Blue
chadob69 is on a distinguished road
How much would it cost if it was an 09 4X2 to go from 3.55 to 3.92?
Old 05-02-2013, 06:51 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Someone on here just did a swap on his 4x2 and said it was $800 install then whatever for the gears (~$300) I think.
The change from 3.55 to 3.92 won't be that noticeable. You need to go to 4.10 or 4.56.
now if you have 3.21 then a swap to 3.92 would be sufficient. But if you are gonna spend the money..make a significant jump. just my advice, it all costs about the same. It's the install that costs $$$$$$$$$ the gears aren't much
Old 05-02-2013, 05:50 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
+1 ^^
What size tires are you running or planning to run? That would also factor in to your decision. But like gonefishin776 said, I would go ride to 4.56's. If you're gonna spend the money, do it right!
Old 05-03-2013, 12:28 AM
chadob69's Avatar
Color: Blue
I plan on putting on 305-55-20 nitto terra grapplers. The only reason i was going to go to 3.92 is i had a 2005 sport that had those gears and it had a lot of torque low end. from reading on in these forums i would most likely go with the 4.10. Just need to find a good place to get the parts and have the work done.
Old 05-03-2013, 12:44 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
We can provide you OE 4.10 gears, 4.10 Yukon gears or 4.10 house brand...plus provide the master install kit too
Let us know
Old 05-03-2013, 12:49 AM
chadob69's Avatar
Color: Blue
Do you know if the 09 already has a LSD. I definately want that especially if going to 4.10
