Old 04-01-2013, 11:00 AM
McDawg McDawg is offline
Vehicle: 01 Dodge Ram
Color: silver
McDawg is on a distinguished road
Default is fuel pressure causing multiple misfires?
the check engine light starts flashing at around 1500 revs under load it doesn't do it when it's in park or neutral. I was told that if the fuel pressure isn't precisely right it can cause misfires. does anyone know those numbers for where I can find that information?
Old 04-01-2013, 11:59 AM
Rep:1890
Spec is 49 psi =/- 5 psi, so "precisely right" isn't really true. Volume is also a concern. You should be flowing about 1/2 pint in about 5 seconds or so.
Old 04-11-2013, 09:55 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Your malfunction sounds far more like an intake plenum vacuum leak, been there twice. Look for the oily telltale residue down the throttle throat with the throttle held wide open. use a good flashlight.
Old 04-13-2013, 07:53 PM
Color: silver
Well, I finally figured it out. I feel like such an idiot, after checking the tune up twice and doing other diagnostics to no avail I had a friend move the number 6 plug wire while I was laying across the engine looking at the distributor and saw the wire on the number 4 post move. Two other people looked at the same thing and didn't see it either, unbelievable.
Old 04-13-2013, 07:54 PM
Color: silver
Thanks to everyone for their help and input.
Old 04-13-2013, 07:56 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
Glad you found it and it did not cost any $$$$$$
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 04-13-2013, 10:50 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
glad you got it all figured out
Thanks
Jeremiah
Discount Auto Performance
