Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
tonneaucovered.com
Old 04-01-2013, 07:34 PM
90Ramd150 90Ramd150 is offline
Vehicle: 1990 Dodge Ram
Trim Level: D150 SE
Color: Blue and white
90Ramd150 is on a distinguished road
Default 90 Ram fuel pump matches 91 year?
I'm changing my fuel pump and replacing gas lines. I took out the old pump and tried to order a replacement. The truck was manufact in 12/1990 so it seems similar to the 91 year pump. Does the newer one lock into the tank the same? Are the fuel pressures the same? Anything I should look out for in particular or is it a direct fit?
