Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-01-2013, 11:20 PM
98 ram 318 98 ram 318 is offline
Vehicle: 1998 dodge ram 1500
Color: blue
98 ram 318 is on a distinguished road
Default whinning noise when in gear
hey guys i have a 1998 dodge ram 1500 with a 318 and a auto tranny .my problem is when i put the truck into gear ,weather the gear be 1st 2nd or drive with my foot on the brake and tranny in gear it makes almost a whinning sorta noise its not loud but its noiticable . until i let off the brake and give it gas and untill about after 10kph it will stop this noise . does any one have a anwers i have spents hours of reaserch trying to figure this out. to any one that can help thanks
Old 04-02-2013, 09:39 PM
igotit igotit is offline
Vehicle: 98 ram 1500
Color: blue
Rep:39
igotit is on a distinguished road
Send a message via Yahoo to igotit
i probally don't have the answer...but someone will.
my 98 1500 318 auto just done something similar,but the whine was loud in every gear but neutral and park.my tranny also wouldn't upshift unless I let off the gas.i wound up replacing all the internal tranny electronics....cost me $145 on ebay,and was easy to do.
plus fluid and filter change.no more whine and smooth shifts.
heres the kit I bought
http://www.ebay.com/itm/251007525539...84.m1439.l2649
Old 04-02-2013, 11:45 PM
Color: blue
are all these electrons under the tranny pan once it is off ?
Old 04-03-2013, 06:10 AM
Color: blue
Rep:39
yes...I had to remove the pan,and valve body....ive never done it before....figured it shouldn't be that bad.
Old 04-04-2013, 12:04 AM
Color: blue
so that kit got ride of the whiining noise completly?
Old 04-04-2013, 03:57 PM
Color: blue
Rep:39
on my truck...yes.
but there are other things that cause whine,the pump could be going out,or the torque converter going out.i just figured for $145...it was worth
replacing on a chance that it may solve my issue.my tranny also had problems upshifting out of gears.
plus my fluid was realy bad,lots of metal shavings in my pan.
but with 162k miles....I have no whine in any gear since ive replaced those parts.
my govoner pressure solenoid....after pulling it and inspecting it,the little screen on the end was completely cloged up with gunk,im assuming it was starving for fluid....possibly causing the whining noise.
my tranny whined in all gears and was quiet in neutral and park.as I drove the whine got louder.
Old 04-04-2013, 08:27 PM
Color: blue
yea i have to tap the gas sometimes to make it up shift also .but my check engine light is throwing a p0720 code witch is a spped sensor i bealive so maybe thats it idk
Old 04-04-2013, 11:43 PM
Color: blue
Rep:39
I had to let off the gas to upshift.i had no check engine light before.but 30 miles after I had the tranny fixed my light is on.ill have see what it for.
Old 04-07-2013, 01:35 PM
Color: blue
all right man thanks for your help
Old 04-07-2013, 02:37 PM
Color: blue
Rep:39
no problem....let us know how it turns out.
