Old 04-01-2013, 11:20 PM
bamott37's Avatar
bamott37 bamott37 is offline
Vehicle: 2007 dodge ram 1500
bamott37 is on a distinguished road
Post Removing the shocks for a leveling kit
Hello, I am attempting to put a leveling kit on my truck and the bottom bolt on the shocks will not come out. I have removed the nut but that is it the bolt will not pull out. Please tell me what I am doing wrong? Thanks
Old 04-01-2013, 11:38 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Your shock is just under a little pressure which is putting that tension on the lower shock bolt. If you are feeling hulkified, you could attempt to push down on your lower A-Arm which will relieve some tension on the bolt, granted, you still have the upper three nuts holding your shock up in place. Or you can use a small pry bar between the lower A-Arm and the bottom of the shock prying lightly to relieve the tension for the bolt to slide out. I forgot to ask; You do have a pair of jackstands under your recommended frame jack points, yes?
Old 04-01-2013, 11:45 PM
mswift's Avatar
mswift mswift is offline
Vehicle: 2007 Dodge Ram SLT Big Horn
Rep:31
mswift is on a distinguished road
I had to hammer mine through on my 2007 I just took a screw driver and a mallet and pushed the bolt through..... you might need someone else to sort of adjust it but it just all depends..... putting them back in is going to be your hard part but it will work I promise!
This truck is sponsered by
https://bullysperformance.com/
Check out there website for great mods at a great price
-Mike-
My work number is 911
Old 04-02-2013, 01:57 AM
bamott37's Avatar
Post Thanks
Thanks for the advice and yes I do have my jack stands in the correct area. Thought I had all the tension off the shock but have not tried putting a pry bar below the shock so I will give that a try. Thanks for the help.
Old 04-02-2013, 07:52 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Are you talking about the lower strut bolt at the lower control arm?
On my 2007 it was seized into the bushing. we had to bang it out...destroying the bushings which we had to sawzall out and replace. And I'm not the only one who had it this bad. Here is a great write up in case you need it.
Spray some PB Blaster or actaully I've heard trans fluid and acetone 50/50 mix? let me double check that. Let it sit over night. Get a big effin hammer and bang it out. It's completely miserable, I had my truck in my buddys garage for a week.
http://www.ramforumz.com/showthread....ght=strut+bolt
link for penetrating oils that might make your time easier
http://www.ramforumz.com/showthread....hlight=acetone
Old 04-02-2013, 09:42 PM
bamott37's Avatar
Gonefishin776 - Thanks that sounds like what I have going on right now. tried everything else so I will have to attempt tearing it apart after I get the new bushings. Thanks for the help.
Old 04-02-2013, 09:48 PM
Rep:1900
good luck man!!!!!!!!!!
Old 06-26-2013, 11:30 PM
Cat Daddy's Avatar
Cat Daddy Cat Daddy is offline
Vehicle: 2012 Ram 1500 4X4
Rep:68
Cat Daddy will become famous soon enough
Default Floor to fender
Can I get a couple of measurements from guys with 5100's installed ....what is your fender height with 2.1 and guys with 2.8 and tire size.....thanks
20X9 Black XD Hoss with painted caps 275x65x20 NittosTerras,Bilsteins 5100's @ 2.1, .75" in rear,laminx tinted head lights,tinted tail lights & 3rd brake light, S&B,Fastman 84 TB,18' Magnaflow,T1000-hemifever,cabin filter,RECON led cab lights,custom dynamic 60" light bar,tow hooks,debadged ,6" shorty ,painted grill and front and rear emblem , AMP power step ,F1 Bacflip bed cover ,Mopar bed rug kit
Old 06-26-2013, 11:34 PM
Grubrunner's Avatar
Rep:3883
My thread is in my signature and the pictures are HERE
Grub out!
