Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 04-02-2013, 03:04 PM
tbucket101 tbucket101 is offline
Vehicle: 2006 Dodge Ram MegaCab Hemi
Color: RED
tbucket101 is on a distinguished road
Default Random Cutting out issue
06 1500 Megacab, 135k, one owner truck just purchased....month into owning it I would notice after hitting a stretch of semi rough road and climbing a slight grade, it would cut out once, then it started cutting out a couple times and now sometimes it will cut our several times and run good for a while.....but it always seems like it does it right after clearing a rough patch of road and always while on the throttle.
Also, the ETC light flashed a few times and sent me into limp mode.
Firestone originally diagnosed the issue as a throttle body and bad battery, but didn't fix the issue although the ETC issue hasn't resurfaced, but the cutting out is still happening. Its been back at Firestone and Ive spoken with the tech who seems to be pretty knowledgeable about wiring and ground issues....nothing can be found as to why it doing it. They refunded my money.
Any suggestions?
Truck will not misfire sitting in my driveway idling, idles smoothly and doesn't have any other issues except for the cutting out.
It feel like a voltage drop from the ignition but its not a single cylinder because of how hard it drops out or maybe a momentary fuel pressure drop but its very quick.
Any suggestions?
Old 04-02-2013, 03:17 PM
RamBiker11's Avatar
RamBiker11 RamBiker11 is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Rep:65
RamBiker11 will become famous soon enough
When you say "cut out" do you mean the engine shuts off or is it just the electronics (radio, cluster, etc) that go out?
Old 04-02-2013, 03:19 PM
Color: RED
Engine loses power and jerks the truck....the lights don't go out or blink...but its a very quick loss of power
