Old 04-02-2013, 03:36 PM
DemolitionMan DemolitionMan is offline
Vehicle: 2013 Ram
Trim Level: Outdoorsman
Color: Maximum Steel
DemolitionMan is on a distinguished road
Default Outdoorsman Transfer Case
I'm (not at all) patiently waiting for my 2013 Outdoorsman to arrive. I came across a forum thread that mentioned that the on-demand transfer case (BW 44-44) is not used on the Outdoorsman. Instead the part-time transfer case (BW 44-45) is standard. As I understand it, the gear ratios are the same between the two. The primary difference seems to be whether or not you get 4WD Auto.
I assume that the part-time transfer case is better for off-roading? If so, why is it better?
