Old 04-02-2013, 06:34 PM
moparman1001 moparman1001 is offline
Vehicle: 2004 Ram 1500
Color: silver
moparman1001 is on a distinguished road
Angry 2004 Ram 4.7 engine running hot
Hello everyone. I have this ram that has lost a very small amount of water. Takes 6 months to need water with no visable leaks. It started running hot last summer if you had it idle for just a few minutes. Water has never come out of the radiator or overflow. I have to put water in it more often but not much. I took it to the shop I use and they could not find a problem. It also has lifter noise when first start it, goes away quickly. Any ideas anyone? Thanks in advance for any ideas.
Old 04-02-2013, 07:59 PM
02Kingstonram's Avatar
02Kingstonram 02Kingstonram is offline
Vehicle: 2002 Dodge Ram
02Kingstonram is on a distinguished road
Well you say hot what's the temp gauge saying? On that note is the temp gauge, Your basis for saying it's running hot? Is it actually? In my past experience the only way to get rid of that pesky noise is drain all that crap oil out, changing it to Amsoil Synthetic 5W30 Signature series along with a new filter and PCV. You live in TN and your putting water in the cooling system, does it get below 0. Do you have antifreeze?
Old 04-07-2013, 01:05 PM
enj808 enj808 is offline
Vehicle: 04 ram 1500
enj808 is on a distinguished road
I had the same issue. Turned out I had a bad head gasket. Exhaust side of number 5 cylinder. Did the gasket and put in a 4 core out of a hemi truck. Much better now. Can you smell antifreeze in your exhaust?
Old 04-10-2013, 09:20 AM
tjbiker031's Avatar
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Well first get a new radiator cap. A loose (or leaking) cap can mess with the boiling point and you will loose coolant from boiling with no clear sign of where it went. Second. Get a Block Tester. Its cheap and will tell you if you have combustion gases in your cooling system, this will rule out or comfirm a blown head gasket.
Old 04-14-2013, 11:27 PM
BigRedQuad BigRedQuad is offline
Vehicle: 2004 Dodge Ram Quad
BigRedQuad is on a distinguished road
I had the same issue over the past few years. Mechanic replaced thermostat and can't remember what else. Seemd to be fine then when taking a trip indicator kept reading HOT the after awhile back to average and no rhyme or reason. After reading on here a few people I advised a new mechanic to look over my radio and sure enough it needed to be replace; I also had no leaks. He showed when I picked up my truck and showed the build up causing the flow to be interrupted and couldn't be cleaned. I hope that helps.
Old 04-18-2013, 09:05 PM
What does a radio have to do with overheating?
