Old 04-05-2013, 03:55 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Originally Posted by Deathrend View Post
That's kind of scary, my grill guard weighs more than that lol (140 shipped, assuming around 120)
Whats scary about it? Iron bull claims they weigh 180/190 but it sure didnt feel like it. I picked up it up, carried it to the truck and held in place while a buddy bolted it up. Sure didnt feel 200lbs. The 12k winch felt jus as heavy.
Even then whats 180lbs...well minus the weight of your oem bumper so its not even that. Not sure where you were going with your comment
[CENTER][SIGPIC][/SIGPIC]
Old 04-06-2013, 12:03 PM
Deathrend Deathrend is offline
Vehicle: 2012 Ram 2500 CCSB 4x4
Rep:42
Deathrend is on a distinguished road
I bet the 180-200 weight is counting the winch. A good 12k will set you back another 80-100lbs.
I just worry about the materials making the bumper. If it's that light, then I worry about what's missing. Is it bracing, is it thin materials? I know some of the first replacements didn't have proper bracing, the first time you used the winch to a tow hook it would bend the frame to a point where you could no longer get it into alignment.
I don't know much about iron bull, so hearing those numbers are a little scary for me.
I'm not huge into offroading though. The only reason for me to add weight to the front is the video below. I plan on adding a winch, but I'm going reciever mount (For utility, two points to mount it on two different vehicles)
His: 2012 Ram 2500 4x4 ST CCSBSold!
2013 VW Passat SEL TDI
Hers: 2010 Ram 1500 Sport CCSB With every option.
Soon to come, 3500
Old 04-06-2013, 06:21 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Iron Bull bumpers are the highest grade A36 de-scaled premium steel, means no mill scale for years of resistance against corrosion and the ultimate bond between the parent metal and finish coating. It's 3/16 inch thick to offer the greatest strength.
My bumper was right around 100-130 with my add-on. Extremely thick metal. My buddy who works construction and has a full replacement ranch hand was amazed at how much thicker and "beefier" it was then his (he now has an Iron Bull).
My bumper did not have tow hooks and I ended up deciding to do a full replacement as it changes the entire look of the truck and definitely is the largest attention grabber (even more than the lift).
Install is extremely easy. 2-4 hour job depending on how hard you work.
SOLD: 2012 Ram 2500 CTD 4x4
Old 04-07-2013, 03:03 PM
candy08's Avatar
Rep:213
^^My man knows what he's talking about....
To tac onto that Deathrend, you said you want a multi mount for front and rear setup. My rear Iron Bull also houses a 12k winch
Here's mine in the white flavor...
Old 04-07-2013, 04:25 PM
panelman61 panelman61 is offline
Vehicle: 2012 Dodge Ram 1500
Color: Deep Molten Red
panelman61 is on a distinguished road
If you go with the stock style, I just took the tow hooks off mine last weekend when I put the body lift on.
1.25 BL, 2.8 Bils, 1.5 Spacers, 20x10 Hostages, 35x12.5x20 Toyo's, 14" Magnaflow, 85mm TB, Vararam.
Old 04-07-2013, 04:43 PM
gofish101's Avatar
gofish101 gofish101 is offline
Vehicle: 2014 1500 Quad Cab 8sp
Rep:46
gofish101 is on a distinguished road
I love the look of the white. Do you have to beef up the front at all for the Iron Bull's and can you install with 2" daystar lift? If I was deciding to go with IB are there any things that I should be aware of or you can recommend? I have an ST with stock black plain jane front Mopar skid plates, Aires 4" oval running boards and American Racing wheels and 17" A/T tires. And could someone suggest the best place to get Iron Bull from in Canada on the west coast Langley BC? And 1 final question which model is the white one?
Thanks Mike
Old 04-07-2013, 05:08 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Did you get new tires?
Thanks
Jeremiah
Discount Auto Performance
Old 04-07-2013, 06:16 PM
Ram725's Avatar
Rep:347
Thanks Mike
Email me at tyler.stephens725@yahoo.com
I know just about everything for their products.
I'll answer all and any questions you might have.
When you are ready to buy, discount auto performance (jhinkle and FastNugly) have a dealer account and can get you your number.
Old 04-07-2013, 06:17 PM
Ram725's Avatar
Rep:347
Thanks
Jeremiah
He did. 38x15.50x20 mud graps.
Old 04-07-2013, 06:33 PM
eodram731 eodram731 is offline
Vehicle: 2009 Dodge Ram
Color: Met Black
eodram731 is on a distinguished road
Here is my Boondock bumper I also have the rear. I really like them.
