Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-03-2013, 01:23 PM
bigblackbeauty bigblackbeauty is offline
Vehicle: 2011 dodge ram
Rep:30
bigblackbeauty is on a distinguished road
Unhappy Help with adjusting cab!
Hey guys, when I look at my truck from front, my driver side tire appears as if it sticks out further than The passenger. I'm thinking that maybe when I installed my 1.25" body lift, as I jacked up one side to fit the spacers In, the cab may have slid over a half inch or so. If I loosen my cab body mounts is there a way to slide/push/pull/adjust my cab so tht it sits evenly between my tires. Also make not the that my wheel alignment is good. I just got an alignment done last week. Any tips or ideas? Thanks!
Old 04-05-2013, 10:53 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
don't you just un-do the body mount bolts and shift it back? then tighten her up? I think that's what I read on someone else fixing theirs. good luck!
and that shouldnt mess with your tire alignment...
Old 04-05-2013, 11:02 AM
Rep:30
Thanks for your reply! Ya I was thinking that's what would have to be done but I'm not sure as to how to go about the actual 'shifting' of the cab. Also I didn't think doing the body lift affected my alignment, I just wanted to rule alignment out as a cause for the off stance look. Anymore Idea sor input anyone? Thanks!
Old 04-15-2013, 03:06 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Just loosen er' off and put yer shoulder into it!
adjust, cab, mounts
