Old 01-13-2012, 02:45 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Grounding out the Throttle Body?
Have any of you guys heard of this? I have a buddy with an 08 ram hemi and he just ran a 10 gauge wire from a bolt on the trottle body over to a grounding location near the battery. And he says that he has noticed a big difference in throttle response.
My only theory on this is: By grounding out the throttle body it takes any ambient static built up on the wires and cleans up the signal going to and from the sensor/pcm? The flow of air going through the throttle body could build up enough static to cause extra noise on the signal and this would clean it up? Making for a more accurate variable the pcm can use to compute?
Any more imformative input on this idea would be awesome!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-13-2012, 02:55 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
There may be some merit to your theory it would be interesting to scope the signal for comparison with or without the extra wire direct to ground. I do have a hard time believing there would be that much static but you never know I guess.
Old 01-13-2012, 03:01 PM
RamTex's Avatar
Color: Stone White
Rep:366
And he is saying the truck is shifting better too! He has had the truck a long time and has raced it alot im sure he would notice a difference if there was one.
Old 01-13-2012, 03:03 PM
RamTex's Avatar
Color: Stone White
Rep:366
Even if there was just a tiny bit of static on the signal this could change a whole lot of things the pcm will do to the whole system. The only way you could test it is to have the return wire hooked up to a spectrum analyzer or an occiloscope and see if over time there is any build up of extra noise on the signal but you would need to know what the threshold is from the factory. Then connect the grounding wire to the throttle body and see if the noise drops.
Old 01-13-2012, 03:06 PM
RamTex's Avatar
Color: Stone White
Rep:366
And hey if it is true you sure cant beat the price of free. Im possitive that 90% of us have some wire just laying aroung the house that a multitude of you guys could try this and see if it really works or if it is just a pipe dream...
Old 01-13-2012, 03:11 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
LOL, I was just thinking this myself. It's easy to do, it's cheap and there is absolutely no harm it could do. Might give it a try just to see if I can notice any difference.
Old 01-13-2012, 03:14 PM
RamTex's Avatar
Color: Stone White
Rep:366
And if it does work i deserve some mega rep points!
Old 01-13-2012, 03:58 PM
nick.gauv's Avatar
nick.gauv nick.gauv is offline
Vehicle: 2006 dodge ram 1500 hemi
nick.gauv is on a distinguished road
from what bolt on the throttle did he connect it too
Old 01-13-2012, 03:59 PM
Rep:1385
I'd love to know if this would actually do anything...
Old 01-13-2012, 05:06 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
quick someone try this, to cold outside where i live to go and give it shot with my aligater clip test leads
