tonneaucovered.com
Old 04-06-2013, 05:34 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Hodgee I'm assuming the 4th gen sway bars from Addco are made the same way as the 3rd gen and if that's the case then the Addco ones are solid. I will hopefully be getting the front one on tomorrow and then the rear one on soon after that
Supercharged, cammed, other things too!
Old 04-09-2013, 01:00 AM
workingram's Avatar
workingram workingram is offline
Vehicle: 2012 Ram RCSB
Trim Level: Express 2WD
Rep:12
workingram is on a distinguished road
Check this one out 1-1/8"
http://www.etrailer.com/Anti-Sway-Ba...id=20121239136
20% tint/debadged sides/blacked out shields,antenna,center caps/trac one rack
Old 04-09-2013, 01:03 AM
workingram's Avatar
Rep:12
And this one 1-5/8"
http://www.etrailer.com/Anti-Sway-Ba...-1129-134.html
Old 04-09-2013, 01:07 AM
workingram's Avatar
Rep:12
And these?
http://**********************/popup_image.php?pID=573
I can't decide on a rear size, don't want to much oversteer?
Also I can't seem to find upgraded links for the front?
Old 04-09-2013, 10:52 AM
AlmostSleezy's Avatar
AlmostSleezy AlmostSleezy is offline
Vehicle: 2011 Ram Crew Cab 1500 Sport
Trim Level: Sport Max
Rep:108
AlmostSleezy will become famous soon enoughAlmostSleezy will become famous soon enough
My main problem is when im going fast enough on the freeway and I want to change lanes and I get body roll. Sway bars will help fix this problem?
Trinity Hemifever 93 tune, 85mm TB, 180ts, Vararam Intake, Magnaflow muffler, ARH longtube headers. Spare tire delete.
All ordered from Bully's Performance.
Best 0-60mph in 5.61 seconds.
Old 04-09-2013, 09:16 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:184
Yes it will help with it to a point.
Other things you can do, lower the truck, and stiffer control arm bushings will also help you out a bunch.
Old 04-10-2013, 02:13 PM
Rep:108
Awesome thanks, I'll look into getting stiffer bushings then since I don't want to lower. Im on 35s haha.
Old 04-11-2013, 08:49 AM
Grimass Grimass is offline
Vehicle: Ram
Rep:76
Grimass will become famous soon enough
Originally Posted by db1 View Post
thanks guys. adcco makes front and back with all the new hardware. for some reason hellwig only makes the rear?
Looks like there is F&R:
Front is 7708
Rear is 7709
Interestingly, rear doesn't come with drop links, so if you need drop links too, you'll need Hellwig 7961.
To be honest tho, I'm curious if going with the Bwoody Drop links and Hellwig sway would be the best solution... Hmmmm...
Old 04-11-2013, 11:54 AM
workingram's Avatar
Rep:12
Front is 7708
Rear is 7709
Bwoody rear links and Roadmaster 1-1/8" rear bar(http://www.roadmasterinc.com/pdfinst/1129-135.pdf) for me.
Does anyone know where to get Upgraded or Heavy Duty front stabilizer/sway bar end links for 2012 Express 2wd, or at least one with poly bushings?
I have searched extensively and the only options seem to be direct oem replacements from moog and off brands? Sphon and maxxlinks make gorgeous ones for 2500's but not 1500's?
So far all I could come up with is to replace the oem upper link bushings by using sizing chart at energysuspension and the same for the oem front stabilizer bar bushings?
It seem to be a vertical ball or inline ball or swivel joint, doesn't look strong at all. Does anyone know if static mounting to the original location with oversized bushings and greaseable bar bushings would work? Many companies have hardened and oversized links without the swivel joint! All you engineers out there please help? There may be to much live action on the control arm for this to work and if so is the factory sway bar even effective? Has anyone taken there's off?
Old 09-20-2013, 01:53 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Spoke with engineer at Hellwig. They do NOT make any front anti sway bars for the Ram 1500 form 2012 forward.
They only make a REAR anti sway bar for 2x4 or 4x4. It is part number 7709.
Engineer could not explain why they don't produce a front anti sway bar.
