Old 04-04-2013, 09:38 AM
Grimass Grimass is offline
Vehicle: Ram
Rep:76
Grimass will become famous soon enough
I'm pretty sure that 'Eco Mode' and MDS are not mutually exclusive. The v6 and 4.7 both have ECO Mode lights as well (Neither have MDS). My Guess is the light comes on when the system sees neutral or negative vacuum.
Old 04-04-2013, 09:50 AM
slowx2 slowx2 is offline
Vehicle: 2015 ram 1500 cc sport
Trim Level: spot/wair
Color: Granite crystal metallic
slowx2 is on a distinguished road
Thanks I will try that tonite when I get home and I will post back. Thanks again
Old 04-04-2013, 10:19 AM
eight-bit eight-bit is offline
Vehicle: 2011 Ram 1500
Color: Green
Rep:107
eight-bit will become famous soon enougheight-bit will become famous soon enough
The Eco Mode light can mean different things for different model years, or different trim levels/motors.
On mine with the MDS Hemi, it means MDS is active.
From what I understand, the '13's with MDS and VVT, the light means VVT is active, and no message at all for MDS.
I would suspect the same of the V6 motors, that the light just means VVT is active since there is no MDS.
Just my .02, hopefully helpful.
Old 04-04-2013, 10:23 AM
Grubrunner's Avatar
Rep:3883
I'm thinking he is referring to KMs per hour, remember he's from Canada Eh Mine's a 10 and stays in ECO mode alot at highway speeds while cruising on level roads.
Oh yeah, duh!
Scared the sheet out of me for a minute.....
Grub out!
Old 04-04-2013, 10:46 AM
Hdscott Hdscott is offline
Vehicle: 2013 Dodge Ram
Color: Grey
Rep:20
Hdscott is on a distinguished road
i agree mine never stays on for more than a few seconds either i cant get anymore than 13.6 miles per gallon i will never see that 25 mile per gallon in my life time that they are bragging about.more than likely they got it from idling on a dyno
Old 04-04-2013, 10:59 AM
Color: Green
Rep:107
We will never see the 25 mpg from the commercial, not in New England at least... Have to move to a flatter area of the country lol
Old 04-04-2013, 11:19 AM
Vehicle: Ram
Rep:76
Actually, The commercial is a Lie. If you look at the EVIC, it's not on 'Gas' it's on 'Messages' -- There is no "Average" bar, and it doesn't say "Images are simulated"... Someone over at dodge marketing should be getting in trouble for this one.
Old 04-04-2013, 02:57 PM
jeepguy's Avatar
jeepguy jeepguy is offline
Vehicle: 2013 Ram Sport
Color: Deep Cherry Red
Rep:29
jeepguy is on a distinguished road
Originally Posted by Ford Apostate View Post
What axle ratio do you have?
3.55 rear end (15 char).
Old 04-04-2013, 03:25 PM
Brians RT's Avatar
Brians RT Brians RT is offline
Vehicle: 04 Ram 2500 4x4 RCLB 13 Ram RT
Trim Level: SLT, RT
Color: Atlantic Blue/Silver, Bright White
Rep:39
Brians RT is on a distinguished road
My truck goes into eco mode a lot. Even towing my racecar it would go into eco mode. That was on totally flat ground and about 55mph.
04 Ram 2500 4x4 RCLB Hemi A5 4"lift 35's
13 Ram R/T Bright White
Old 04-04-2013, 03:30 PM
dc01039's Avatar
dc01039 dc01039 is offline
Vehicle: 2014 RAM 4x4 Crew Cab
Trim Level: Tradesman
Rep:27
dc01039 is on a distinguished road
Originally Posted by mrpositraction View Post
You have to turn it on through your Radio and the settings. Once it is turned on then it will display in your lower left hand side of your EVIC. It is big and green, you won't miss it. Mine was off from the factory and I had to turn it on.
Thanks, I had the same question...!! I guess I need to read the damn book...ARGH...!!!
