Old 04-08-2013, 01:27 PM
blitzkrieg95 blitzkrieg95 is offline
Vehicle: 2011 ram
blitzkrieg95 is on a distinguished road
Anyone have a 6" lift with helper airbags ?? Or should I ask is it possible to to have both ?
Old 04-08-2013, 01:38 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
I've heard the TLC is working on a bracket to use their bags with a 6" lift. I also contacted Airlift about using Airlift 1000's with a 6" lift and they said you would need to buy bigger air bags. I'm assuming they have them in stock. I also think I saw a guy with a 6" lift running Airlift bags on the forum once. Don't remember who it was though or where I saw it.
So overall, yes I think it is possible.
Old 04-08-2013, 02:05 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
I have to agree with them on this one I also have my bags separate going to the rear licence plate not "T" when your towing it keeps your load even the air stays where you want it, with the T it basically pushes the air from one bag to the other momentary lop-siding you.
my 2 cents
Old 04-08-2013, 04:58 PM
bearsram's Avatar
bearsram bearsram is offline
Vehicle: 2012 Ram crew
Trim Level: sport
Color: flame red
Rep:23
bearsram is on a distinguished road
I had the air lift 1000 on my 09, I pulled my 30 ft rv, my utility trailer with the atv's or fire wood.. Any how I love them, I have the on board compressor as well. its all being installed on my 012 this Wednesday.
2012 1500 Hemi Sport 3.92, NAV, Alpine, Sunroof, Trailer tow, Brake Contoller, Rear Cam, Sport Hood,
Old 04-08-2013, 09:48 PM
blackhound1 blackhound1 is offline
Vehicle: 2011 Dodge Ram 1500 Quadcab
Trim Level: Lonestar Edition
Color: Blue
blackhound1 is on a distinguished road
I installed the Airlift airbags last weekend and will be picking up my new travel trailer this coming weekend. Hoping for some good results.
Old 04-08-2013, 09:57 PM
Hemiman345's Avatar
Hemiman345 Hemiman345 is offline
Vehicle: 2010 1500 4x4
Color: Inferno Red
Hemiman345 is on a distinguished road
Installed mine today. I will test with 600lbs of shingles in the morning
Old 04-12-2013, 09:17 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I used the T also. I pull a travel trailer and it really helps it stay leveled out.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 04-14-2013, 07:33 AM
TexasBorn TexasBorn is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Lone Star
Rep:99
TexasBorn will become famous soon enough
does installing these air bags increase the payload capacity at all? or is it strictly ride and handling?
Old 04-14-2013, 08:44 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
[QUOTE=JMS4218;1062984]For those who have the air lift 1000's do you have each bag filled separate or by using the T fitting have the air go to both. I am trying to figure out which way is better. I like both but at times it would be nice to have them separate for greater stability and ability to adjust for load.[/QUOTE
IMHO, I think separate lines are safer, for example, with the lines inter-connected, when entering a long continuing curve in the road while pulling your travel trailer or any trailer with weight, with cetrifugal force acting on your vehicle, your vehicle will try to roll to the outside of the curve, in turn "unloading" the airbag on the inside, air from the outside bag will transfer to inside bag aggrivating the "rolling" tendency causing more instability. Won't happen with separate lines.
Old 04-28-2013, 01:41 PM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
[QUOTE=Otterdriver;1069263]
I guess If you dont fill them all the way. When towing I fill them to 35 so it don't matter. When not towing I keep them 5-10 just so they dont get crushed in the springs. Even at 25 I couldn't imagine much air transferring from bag to bag and making that much a difference. Airlifts are just a helper bonus anyways, only time I would really worry about instability is going over the payload or tow rating, my opinion anyways.
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
