Old 04-04-2013, 02:10 AM
JFleury JFleury is offline
Vehicle: 2007 dodge ram
JFleury is on a distinguished road
Default Coolant spraying all over engine
My truck started overheating and every time I add coolant and drive anywhere coolant sprays all over my engine looks like the majority of the coolant is under the air intake. Replaced a radiator hose that badly needed replaced. I'm at a loss at what this could be. Any help would be greatly appreciated
Old 04-04-2013, 09:34 AM
Kman521 Kman521 is offline
Vehicle: 2013 Dodge Ram
Kman521 is on a distinguished road
Look on the underneath of the water pump, it could be your pump is shot.
Old 04-04-2013, 11:00 AM
I push the skinny pedal
Rep:3277
I would bet the water pump as well.
Kurtis
Old 04-04-2013, 01:44 PM
Rep:2616
any coolant under the hood will fly all over because of the fan
your vehicle is a 2007 & all your hoses & belt(s) are due for replacement
When your engine is cold, grab a rag & clean the underside of the water pump off
then feel with your fingers for a hole about the size of a pencil, it will be right under the shaft that the fan is attached to
That hole will be where the water leaks out, when the water pump is going out
If it is leaking there, I would pull out the radiator, easy to do on a 2007 Ram, take the radiator directly to a REAL radiator shop to get it flushed, pressurized & if the shop says that you need it, get it RODDED OUT.
Then drive back home & pull the water pump & drive it to the auto parts store for a replacement & anti freeze, then install it, change all of the older hoses & belt(s).
By that time the radiator shop should be done with your radiator.
Go pick it up & it should look like new, painted & all, take it home & install it. The cooling system should last you another 5 to 7 years
Good Luck
Looks like the closest radiator shop is
Joe's Radiator Shop
2 9th Ave W, Kalispell, Mt.... 20 miles SW
(406) 257-5759
