Old 01-07-2014, 07:34 PM
NIck11 NIck11 is offline
Vehicle: 2014 Ram 1500 Sport 6'' BDS li
Rep:45
NIck11 is on a distinguished road
Default Post HID / LED Bar installation Question
Folks, got my 55w 6000k HID's installed in my highs/lows/ and fogs today. Took it to a shop which specializes in doing lighting for new dodge's. Everything looks GREAT, the LED light bar + my HID's really lights up the road when required.
Only concern I have is under my stored messages I have a low beam / Tail light out message. Does this mean these messages are stored from during the installation, or is there a problem with how they were installed??
This company uses the Lumen HID kits that everyone uses to avoid CEL's and what not....
Let me know what you guys think, REALLY wanting to avoid bringing it back to this shop even tho it's warrantied. "Dropping off my vehicle and getting picked up is a real pain in the ass"
I got it all installed on my 2014 Ram 1500 Sport
Old 01-07-2014, 07:43 PM
Rep:45
Just to be thorough the HID's "Both His/lows/fogs" were installed using their own harness.
I have no issues with flickering or anything like that they work beautifully, I just have two error messages stored "brake lights out and low beams out".
Old 01-07-2014, 08:33 PM
Rep:45
Old 01-07-2014, 08:40 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Well the only advice I can offer is if they are stored messages it was likely a trail and error during install.
I would just clear them out and move on. I would only be concerned if they started coming back.
Chrome... in moderation.
Old 01-07-2014, 08:47 PM
Rep:45
How do you clear the stored messages?
Old 01-07-2014, 10:08 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
I think if you turn your key to the on position and completely press down the gas pedal 3 times with in 10 seconds should reset the message center.
Old 01-07-2014, 10:32 PM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
I believe every time you turn on the truck it runs a check. When I installed my lights from Jeremy at the retroshop with a harness I had a passenger side bulb out error there in the stored messages. They started having issues and I put stock bulbs back in, error went away. Also had a canbus kit in for awhile before and never had an error on the dash. Think you need to take it back to them.
Old 01-08-2014, 03:12 AM
res1551cue's Avatar
res1551cue res1551cue is offline
Vehicle: 2012 Ram 1500 QC
Trim Level: ST with Ram Box
Rep:37
res1551cue is on a distinguished road
It is probably because HIDs are gas filled bulbs where as stock bulbs are filament bulbs. Trucks that arent wired for HIDs will come up with an error when HIDs are installed because it does not recognize it has having a bulb installed. It is a common error with HIDs. With my previous HID set before I got them from RetroShop I had to buy a Warning Cancellor Capacitor which was designed to fool the computer into thinking there was a halogen bulb installed and not an HID bulb. I hope this helps.
2012 Ram 1500 ST Quad Cab Flame Red with Ram Box
Upgrades: 6000K Fogs; 2013 OEM Projectors; Black 5" Oval Nerf Bars; Plasmaglow Fire and Ice Tailgate Bar; BakFlip FiberMax Bed Cover; LEDs; Bed Cover Lights
My Build
Old 01-08-2014, 03:47 AM
Rep:45
Thanks for the advice, however this may be a bigger problem as why would my brake light out warning light be on....
Either way I will be bringing my vehicle back *sigh*.... why o why did Chrysler have to make getting HID's this difficult on these trucks...
Old 01-08-2014, 03:50 AM
res1551cue's Avatar
Rep:37
Is your brake light actually out? They have blown a fuse in the module and replaced it and just forgot to clear out the computer.
My Build
