Painting mirrors and door handles???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 04-04-2013, 10:39 AM
Jake frank Ram's Avatar
Jake frank Ram Jake frank Ram is offline
Vehicle: 2013 Dodge Ram 1500
Jake frank Ram is on a distinguished road
Default Painting mirrors and door handles????
Just got my 2013 dodge ram express and want to paint my mirrors, door handles and the lower air dam were the tow hooks usually go.
Does anyone know how to go about getting the Exact color and if I can paint on top of the plastic????
Want it done right not a shitty back yard job
Old 04-04-2013, 10:56 AM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2017 Jeep Grand Cherokee
Trim Level: Laredo 75th Anny
Color: Billet Metallic
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Pretty simple. Take it to your favourite auto paint shop and get it done. Case closed.
No More RAM
Old 04-04-2013, 03:13 PM
Thank you for the help hope to make the truck look clean soon
Old 04-05-2013, 01:30 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Getting the color is easy and you can paint it. The mirrors and air dam aren't hard to do and I can tell you how to easy enough. To do door handles the right way is another story. I do this everyday and I can tell you having a pro do it will result in a better job like anything else. I plan on painting the mirrors on my 13 since the handles are chrome I am leaving them for now. You can go to any Dupont or PPG store and they can mix the color for your truck and put it in a aerosol can. You will need adhesion promoter, wax and grease remover, gray scotch bright pads, SEM soap, primer, good masking tape, good painters masking paper, the paint and also clear coat.
The problem with the handles is to do it properly you should take them off the truck. I haven't taken them off a 4G ram so I can't say if it's hard or easy.
If you want it to look good without a hassle take it to a shop they have all the supplies and exp to do it right and they will warranty the work. I do mirrors for $150 to $200/set. Handles would probably Charge $200 a pair. Air dam $150. But if your having it done at once then they will give you a deal. If some one brought me on to do I would probably charge between $400 and $500 for everything. It can be done in a day. Hope this helps you out.
Old 04-05-2013, 01:02 PM
Rep:388
I figured that based on his first post that a DIY solution was not an option.
No More RAM
