Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-04-2013, 01:01 PM
SCme SCme is offline
Vehicle: 1988 Dodge D150
Trim Level: Base
Color: Grey
SCme is on a distinguished road
Default Intake Manifold and Carb
New to the forum and new Dodge owner. Bought an 88 D150 with the 5.2, just over 100k miles. The TBI is not working well, and when I got it, the cat had already been cut out and pipes welded up. Pulled the motor recently and have it stripped down, but decided to do the carb swap and pull the smog stuff off since it was all plugged/disconnected/non-existent already. Thinking that I may run down to one of the local salvage yards here and grab an 1987 or earlier intake manifold, instead of buying one from Summit. Does anyone know if a pre-88 intake manifold will bolt right up to my 88? Thanks.
Old 04-04-2013, 01:17 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
Pre '88 intakes should fit without issue.
Old 04-04-2013, 10:23 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
if you are grabbing a carb and intake off a older engine make sure it does not have lean burn system. lean burn carbs don't have a vacuum advance port. they usually have a computer behind the fender or on the air cleaner. if you can find a 86-87 and it don't have lean burn setup you should grab the wiring harness, distributor and all the electrical components. a 86-87 wiring harness should just plug in but you may have to unplug the fuel pump. plus getting the proper vacuum advance distributor and on the individual components and wiring harnesses could cost about $200-$300 if you have to buy them new.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 04-05-2013, 11:32 AM
Trim Level: Base
Color: Grey
Good stuff to know. I think I am going to go with a new Edelbrock carb and headers, so the intake is the only thing I will need right now.
Old 04-08-2013, 02:24 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
In that case you'll need the Edelbrock Performer intake. It has smallish intake ports closer to 318 size. It's 50-state legal. The only 318's that had 4V carb from the factory was the E46, and consisted of the 360 intake and heads with matching large ports.
Old 04-16-2013, 10:27 PM
friendlyHP's Avatar
friendlyHP friendlyHP is offline
Vehicle: 2004 Dodge Ram AWD
Trim Level: Laramie 4x4 quadcab
friendlyHP is on a distinguished road
gotta love Chrysler LA blocks
1992 Dodge Ram EFI 5.2 150 1996 Dodge Dakota Sport EFI 5.2 4x4
2004 Dodge Ram Laramie 4x4 (AWD)
