Old 04-04-2013, 08:30 PM
Roguebishop Roguebishop is offline
Vehicle: 2013 Dodge Ram quad
Trim Level: Outdoorsman
Roguebishop is on a distinguished road
Default Question about 2013 4x4
So i have a 2013 4x4 outdoorsman and trying to understand what type of 4x4 i have now.
I am use to the old and really old 4x4 the type where you use to get out and lok your hubs in and the type where you had a separate control shifter for rwd, 4wd hi and 4wd low. Now I have a know that says 2wd, 4wd lock and 4wd low.
is 4wd lock the new 4wd high or is this actually saying that it is locking in all 4 wheels like actually lockers (that is awesome if possible)
Sorry been out of the 4x4 for a bit and having to get re accustomed.
Old 04-04-2013, 08:34 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Lock is 4w high, and low is low.
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
4wd lock is essentially 4hi and 4wd low is essentially 4low. Neither lock up all 4 wheels though, you still have an open diff. Unless you have the limited slip rear end (I'd assume the outdoorsman's do). That will help you on the back axel but it's still not fully locked.
Old 04-04-2013, 08:49 PM
jeepguy's Avatar
jeepguy jeepguy is offline
Vehicle: 2013 Ram Sport
Color: Deep Cherry Red
Rep:29
jeepguy is on a distinguished road
Does anyone have info on the Auto 4WD?
Old 04-04-2013, 08:52 PM
Rep:2032
I believe if you have it in 4wd auto and the rear tires start spinning the truck will automatically engage the front wheels.
Old 04-05-2013, 10:11 AM
thanks much appreciated That is just one more thing to add to my list.
Old 04-05-2013, 04:54 PM
GuyGene's Avatar
GuyGene GuyGene is offline
Vehicle: 1993 Dakota
Engine: 1992-1991 239ci (3.9L) Magnum V6 180hp
GuyGene is on a distinguished road
I've never had a 4WD but always wanted one. I'll see, but man, these new Rams are awesome!! Makes it mighty hard to resist!
That old man, he don't think like no old man. "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
"I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
Old 04-05-2013, 05:54 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
It's what others have already said... The only thing I'd like to add is about the hubs. The reason you no longer have to manually lock the hubs is because they are always locked.
I'm not sure on the 1500s but Chrysler has used something called CAD, in the past. What CAD does is it disconnects the front axle, when 4WD isn't used. It's kind of like unlocking the front hubs but not as efficient because the locked hubs are still spinning everything in the front axle, instead of just the wheels.
Old 04-05-2013, 06:26 PM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
I always wondered why in this day in age when they are trying to get better fuel mileage out of 4x4 trucks that they don't have free spooling hubs like the old manual hubs but with an electric device that would lock the hubs so you don't need to get out and turn them manually. This would also save on wear on the front driveline.
Old 04-05-2013, 06:37 PM
Rep:2032
Ya I definitely don't get why they haven't figured that out yet. Could be the cost of it or maybe they haven't figured out how to make it strong enough yet. Who knows... But it's something I'd definitely like to see.
