Old 04-04-2013, 08:46 PM
Mojack's Avatar
Mojack Mojack is offline
Vehicle: 2012 Ram 1500 ST
Color: Deep Cherry Red
Rep:65
Mojack will become famous soon enough
Default 2012 Ram 1500 non rear hitch/cross member
My '12 came without the receiver hitch, I thought someone might like to get rid of their cross member with welded on receiver and trade for mine. I'd like to be able to tow occasionally, if you don't plan on towing and want a cleaner look for your back bumper....
2012 Ram 1500, 1986 RamCharger,
1972 Duster 340, 1965 Valiant 340
Old 04-04-2013, 10:31 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
FYI I think if you crawl up under there you will see the hitch is bolted to the cross member.
Sean
Old 04-04-2013, 10:46 PM
Mojack's Avatar
Rep:65
Nope, I have looked at it extensively...naked cross member. I can order a bolt on receiver with a lower rating than the welded cross member/receiver, but I'd rather have the welded one.
I am talking about the receiver type not the through the bumper hole. Thanks!
Old 04-04-2013, 11:01 PM
snrusnak's Avatar
Rep:1385
Ok I can't say for sure but I just know every ram I've looked at had a class III bolted on it from the factory that looks like this:
http://www.knowwhere2jeep.com/curt-d...iii-hitch.html
I bought an aftermarket class IV for my truck that is like this:
http://www.etrailer.com/Trailer-Hitc...FQr0nAodSFkAsA
Sean
Old 04-04-2013, 11:05 PM
Mojack's Avatar
Rep:65
Yep, the class lV is what I'll have to go with if nothing factory turns up.
Old 04-04-2013, 11:08 PM
snrusnak's Avatar
Rep:1385
Ok gotcha. I highly recommend that curt hitch I posted. That's what I bought(was on sale for the same price as the class III when I bought it) and although it took a little longer to install(have to fish some washers/nuts in the frame rails) it is extremely heavy duty.
Sean
Old 04-05-2013, 03:46 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Your link for nowhere2jeep shows a class III hitch. Dodge has the class IV in the same style as that is what I put on mine. The only difference in towing capacity is that it requires the use of a weight distribution hitch to achieve the higher towing rating otherwise it will handle the same as a class III.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 04-05-2013, 06:56 PM
snrusnak's Avatar
Rep:1385
factory hitch is a class III. There may be an upgrade I'm not sure, but obviously it'd be different. If it were the same then it'd be a class III.
Sean
Old 04-05-2013, 07:01 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Factory hitch on the Rams is a class IV not a III. You'd definitely want to go with at least a class IV.
Old 04-05-2013, 07:14 PM
snrusnak's Avatar
Rep:1385
maybe the newer rams are different. 2010 and older had a class III. class III is 6000 lb. class IV is 10,000 lb. Class III is more than sufficient for most rams and most people.
Sean
