Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 04-04-2013, 11:49 PM
Fizban321's Avatar
Fizban321 Fizban321 is offline
Color: Grey
Fizban321 is on a distinguished road
Default Transmission problem after first service
I had the transmission serviced on my 2010 4.7 a couple weeks ago at my brothe in laws shop. There was an issue with the filters required. One of the filters for a 2010 ram did not match the old filter. After sending the replacement and original filter back to the parts store, I was told the original filter matched that of a 2008 ram. The 08 filter fit and all seemed fine. A few days later I started to notice a little delay in the transmission when shifting from park to drive or reverse after the truck sat a while. I have noticed this a few time over the last couple werks.
Has anyone else seen this or know what could be causing this?
Thanks in advance
Old 04-05-2013, 11:23 AM
Resident Technician
Rep:1915
You didn't use OEM filters?
Old 04-07-2013, 10:55 PM
Beshears8807's Avatar
Beshears8807 Beshears8807 is offline
Vehicle: 2010 Dodge Ram 1500 crew cab
Color: Blue
Beshears8807 is on a distinguished road
hey ram tech im new to this site and have seen alot of posts from you and seems like you have alot of knowledge and wanted to ask you a question. I have a 2010 ram crew cab 5.7 and when im driving on the highway around 60 and punch the gas the whole truck shakes. it happens about %10 of the time. any idea what it could be?
Old 04-09-2013, 11:50 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Good info here:
http://www.ramforumz.com/showthread....ht=545rfe+step
I'd guess you used aftermarket filters and it didn't have the anti drain back valve, which is where ramtech was headed I believe.
Sean
Old 04-09-2013, 11:31 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Same here! Been getting the downshift shudder since day one. I can more or less duplicate it now - always going about 45-50, in Eco, downshift to merge or pass, and shudders like its quickly in and out of the gear. I heard there was a flash for the condition but I just haven't focused on it now that I am in my extended warranty period.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2012 Jeep Grand Cherokee Limited
Old 05-28-2013, 11:54 AM
05 bee 05 bee is offline
Color: Deep water blue/light sandstone
05 bee is on a distinguished road
I have the same issue... I couldn't make it do it for the DODGE tech
Old 05-30-2013, 03:39 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
the flash fixes it but it makes the shift VERY soft and spongy. Its like they detuned it to hide the real issue. Because i had this issue as well, happened off and on with the shuddering, then i got a custom tune, and its even more obvious now from the extra power.
Pretty sure it needs a new torque converter
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 05-30-2013, 04:09 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
New Torque Converter (2800 Street Edge) didn't make a difference on mine. Still does it.
The 545RFE is just a turd, needs better clutches/frictions, valve body and line pressure. (and tuning)
It's basically the same trans Dodge has been using for over 10 years,
back when the first Hemi Ram was only 345 crank HP.
Old 07-14-2013, 06:09 AM
Prochargedram's Avatar
Prochargedram Prochargedram is offline
Vehicle: 2010 Dodge Ram R/T 1500
Trim Level: R/T 5.7Hemi
Color: Blue
Prochargedram is on a distinguished road
i had same issue,
i did the tranny oil change at the dealer
& know the truck only runs to 3rd
but i wana see if MGH helps out with my tranny
& builds me one like his
Old 07-14-2013, 11:30 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:736
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
op, did you use chyrsler trans fluid or aftermarket?
